05-15-2022, 10:53 AM | #1 |
Need A Screw Driver
I lost my 3/8" wide flat blade screwdriver that I used for the distributor cam screw. After searching in many many places, I have not found a 3/8" wide flat blade screwdriver. Where can I get one?
Bob Bidonde |
05-15-2022, 11:02 AM | #2 |
Re: Need A Screw Driver
I got mine from Harbour Frieght a few years back. It's the largest one they carry. I just measured the tip and it's .350", only a 32nd under 3/8".
Regards Bill |
05-15-2022, 11:25 AM | #3 |
You can always make one fit.
05-15-2022, 11:31 AM | #4 |
Ace hardware carrys the craftsman stubby one. Several with different blade thicknesses.
05-15-2022, 01:11 PM | #5 |
05-15-2022, 01:31 PM | #6 |
Paul in CT |
05-15-2022, 03:15 PM | #7 |
Proto and probably others make a 3/8" blade that fits on a 3/8" square drive.
05-16-2022, 07:58 AM | #8 |
Thanks all for your tips.
Bob Bidonde |
05-16-2022, 08:47 AM | #9 |
I would not recommend a Snap-on screwdriver. Unless they have changed the material the handles are made of in recent years, it will deteriorate in a few years. Everyone I bought did the same thing. They will crack and become brittle and finally break off. Good luck getting them replaced
Two things I have learned over the years. Don't buy Snap-On Screwdrivers or Timing Lights.
The Master Cylinder Enjoying life at the beach in SoCal... |
05-16-2022, 08:54 AM | #10 |
I bought these bits from Amazon.com for the wide blades. 5/16" drive.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The Master Cylinder Enjoying life at the beach in SoCal... Last edited by The Master Cylinder; 05-16-2022 at 09:01 AM. |
05-16-2022, 08:56 AM | #11 |
Snap On dealers will replace the handle with no charge or replace the entire screw driver. The only problem is that the latest style driver will be the replacement and it may not match an older style. They finally moved away from the type of plastic that chemically deteriorated but it took quite a few warranty replacements before they finally did. I've had many a handle and driver blade replaced and it never cost me anything.
My 40 year old Snap On timing light still works just fine. Not a lot of cars even need a timing light in this day and age. |
05-16-2022, 09:04 AM | #12 |
Instead of throwing away the screw driver just make one out of a hard wood like oak or ash and turn on a lathe where rounded then drill out the hole for the back end. Wood would last a lot longer than plastic.
05-16-2022, 10:01 AM | #13 |
Haha, The only problem, good luck catching up with a "dealer".
05-16-2022, 11:00 AM | #14 | |
And if you do and you're not a professional or regular customer the chances of getting a replacement are slim to none. I bought a Snap On stubby 3/8 ratchet at a yard sale with stripped gears. Luckily a buddy who has a shop had a new dealer wanting his business so he was able to get it repaired. Best 50 cents I ever spent. Per the dealer the ratchet was made in 1969.
Making the simple complicated for over 30 years. |
05-16-2022, 11:01 AM | #15 | |
That may explain why I have not bought snap-on tools in decades I still go to the flea market to search\buy old tools, they can be cleaned up...and they work without breaking...and they're cheap
05-16-2022, 07:38 PM | #16 |
I know where my Snapy dealer lives. He will get me whatever I need in one way or another. I haven't bought a screw driver in years. Some folks will pay more for a good quality antique screw driver than they will for one with a life time warranty that is made in US. All of them wear out. Folks used to buy Craftsman at their Sears & Sawbucks store but they don't anymore. They all buy the cheap stuff and they get what they pay for.
05-16-2022, 08:03 PM | #17 | |
And the screwdrivers, has anyone else had a terrible smelling substance oozing from the handle of Snap-on screwdrivers, then crack and break. I have had several do that. Others just crack.
Ruth "Sometimes you really DO need to read the whole thread" |
05-17-2022, 08:20 AM | #18 |
The modern ones from say 2000 on have been very reliable. My first set was 1980 vintage and they all went south years ago. I wear the bits out before the handle on the modern ones. The phillips head drivers wear out faster than a straight blade since most screws are phillips in aviation. Now days we use more and more torx type screws so a person has to get a replaceable bit type driver to do those.
The Snappy man came to me and yes, their tools are expensive but I've abused them time and time again and I still have most of the ones I originally purchased over 40-years ago. I still have all the old ratchets but most have the replacement titanium gear sets that I paid no money for after repairs. I bought all that stuff so long ago that it was cheap by todays standards. Snap on doesn't even make a lot of it any more. I'll never regret investing in good quality US built tools. I made a lot of green with them. I always had good relationships with Snap On dealers. Some are even old car and motorcycle buffs themselves. They always bent over backwards to get things for me. One that was a gun dealer even gave me a valuable gift for bailing him out on a deal where a customer reneged on an order. I needed the tool box anyway and got a bonus out of the deal. If you want a good flat blade screw driver that your ancestors may have used to work on a model A distributor cam then look for a larger blade H.D. Smith & Co. "perfect handle" screw driver. They are still out there. http://alloy-artifacts.org/hd-smith-company.html Gunson is the modern day equivalent but I don't think they are made in the US anymore. Last edited by rotorwrench; 05-17-2022 at 08:29 AM. |
05-17-2022, 09:20 AM | #19 |
Bob,
Not exactly what you are looking for, I do find this one works very well adjusting the Model A distributor cams. Ebay # 284817472574 (not connected to this sale) jb |
05-17-2022, 12:27 PM | #20 | |
Snap On is now making some of its tools off shore as well. Most hand tools are still US made but for how long? https://agradetools.com/snap-on-usa-or-china/
