03-29-2022, 04:28 AM | #1 |
Logo Lites - Replacing the Turn Signals
I've bought a set of Logo Lites and dont like the look of the actual turn signals and want to change them. They are quite a bit bigger than I thought, no one's fault but my own.
The signals themselves are one wire with ground through the controller. Has anyone used the kit and replaced the signals with smaller LEDS? If so any issues with the other LEDS having a ground which I assume I would just ground myself?
Looking for an unrestored 33 34 3W or 5W coupe. Thanks |
03-29-2022, 07:02 AM | #2 |
Re: Logo Lites - Replacing the Turn Signals
I just use the lights Henry Ford provided. I don't like the add-ons. JMO
03-29-2022, 08:19 AM | #3 |
The LED signals ground through the chassis. Think about it, there's only one wire. The circuit has to complete somehow. The Logo Lites instruction manual says so in the Troubleshooting section.
03-29-2022, 10:45 AM | #4 | ||
Ruth "Sometimes you really DO need to read the whole thread" |
03-29-2022, 01:15 PM | #5 | |
To the best of my knowledge Henry put lights on both the front and rear of these monsters. Most have had the right rear light added at some time. The top bulb is for brake/turn. Bottom is tail. I use the cowls and parks for the front turns. If the rears have LED and the front higher CP incandescent they are plenty bright and a thermal flasher works fine. |
03-29-2022, 03:27 PM | #6 |
03-29-2022, 05:37 PM | #7 |
I love Logo Lites. Relatively unobtrusive, easy installation, and people can readily see them. A huge plus for safety in modern driving.
03-29-2022, 06:24 PM | #8 | |
03-29-2022, 11:15 PM | #9 |
03-30-2022, 06:22 AM | #10 |
03-30-2022, 09:53 AM | #11 |
03-30-2022, 02:13 PM | #12 |
Not trying to be right, trying to clarify what an add on consist of??
