Old 09-27-2022, 12:26 PM   #1
Bobby O
Default Choke cable
Thanks for all the info on the lights. It was my switch. I replaced it. Now I'm trying to remove the choke cable from the dash. How do I do it? Has anyone done it? 55 Ford Vicky. Thanks.
Bobby O is offline   Reply With Quote
Old 09-27-2022, 06:50 PM   #2
paul2748
paul2748's Avatar
Default Re: Choke cable
Not familiar with a 55 Ford choke cable, but usually cables of that type have a nut behind the dash that you undo
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-27-2022, 11:19 PM   #3
Daves55Sedan
Daves55Sedan's Avatar
To remove '55 Ford choke cable, first loosen one screw at the carburator choke lever (but do not remove the screw), then loosen the cable retainer bracket and pull the cable out thru the back of the bracket. Now go under the dash with an open end wrench and unscrew the hollow metal nut that holds the cable in the dash. At first just loosen the nut with a wrench, then you can get your hand in there and unscrew it the rest of the way. Once the nut is off, carefully pull the choke cable out of the dash and thru the firewall grommet, picking up the nut when it falls on the floor.
Daves55Sedan is offline   Reply With Quote
Old 09-28-2022, 11:31 AM   #4
Bobby O
Thanks for the info on the removal of the choke cable. I pulled it out this morning. Thanks again.
