01-01-1970, 12:00 AM | #1 |
Guest
Posts: n/a
Re: 1979 351 M Lacks Power, Missed and Surges
Hmmmmm, shouldn't be the timing chain with that low a mileage; I agree with Robert, it could be the ignition module. Before that though, I would check the coil (switch with a known good coil; you do keep one haning around, don't you?)Surging could also be the carb. A good tune up shop should be able to rule out one by one the electronic possibilities with a diagnostic machine. Good luck! <table><tr><td><font face="arial"> |
