08-16-2021, 08:21 AM | #1 |
High Compression Head Replacement
We are considering getting a high compression (actually more of a medium compression) head to replace the aluminum head on our Model A's engine. Specifically I have my eye on the 5.5. to 1 ratio head offered by some of the on-line model a stores. I assume that the aluminum head already on the engine is high compression. (we measured the compressions on each cylinder and they were around 75 psi each.) Should I be able to just simply replace the head or are there other considerations that would need to be done with the other internal engine parts, given that it already had a high compression head? If we do this we will get the higher quality studs etc. What about a gasket? What is recommended? I think that Snyders had one they recommend.
If we went up to a 6.0 to 1 ratio head is that a game changer? Bill Walworth, New York Last edited by philcobill; 08-17-2021 at 11:48 AM. |
