Old 03-10-2016, 07:24 PM   #21
David Williams
Default Re: Going Crazy Smelling Gas Fumes
I had a similar problem with my 29 AA, turned out there was a pin hole leak behind the tank up high between tank and fire wall. l Had to use a mirror and flash light to find it. Was hard to prep but fixed it with JB weld.
David Williams is offline   Reply With Quote
Old 03-10-2016, 08:54 PM   #22
Fred K-OR
Fred K-OR's Avatar
See post #3. I agree it could be something like this.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 03-10-2016, 09:30 PM   #23
leadpot
leadpot's Avatar
Never thought about a leak in the upper front section of the tank. Is there a particular problem area ?
leadpot is offline   Reply With Quote
Old 03-10-2016, 11:06 PM   #24
Fred K-OR
Fred K-OR's Avatar
This does not normally happen but it seems like you have done everything else to check out the normal things, so it is worth a check to see if you may have something like this. It may not only be in the front section but could be on sides also. I had a hole in my huckster tank in the side of the tank that was made by a bullet many years ago. I tried patching it, had a radiator guy try to patch it and never could get it patched. So I went and put a coating inside of the tank and that took care of it
Good luck and hope you find something. I would guess you are getting rather frustrated by now not being able to pin it down.
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 03-11-2016, 12:33 AM   #25
Tom Wesenberg
Tom Wesenberg's Avatar
About 15 years ago I worked on a 1930 and couldn't get the inside line to seal at the firewall connection until I tinned the flare on the brass end. That sealed it right up.
On my Model A that same brass end had a small crack, so I made a new end for it, and made the tapered lip just a hair thicker for added strength. Also the original brass end only had a small ring of solder to seal it to the steel tube. I made sure the full junction had solder for more strength.
Old 03-11-2016, 08:40 AM   #26
leadpot
leadpot's Avatar
Appreciate all the help, will check tank over carefully, thanks again.
