Go Back   The Ford Barn > The Swap Meet > Wanted > Early V8
Old 07-18-2010, 05:00 PM   #1
casper
Default Wanted: 1933-34 Ford car or 1/2 ton truck frame
City: Fresno
State: Ca.
I just need the bare frame. I may consider a roller with original front and rear axle. Thanks!.................. [email protected]
casper is offline   Reply With Quote
Old 07-23-2010, 12:23 PM   #2
casper
Default Re: Wanted: 1933-34 Ford car or 1/2 ton truck frame
btt.
Old 08-02-2010, 07:17 PM   #3
casper
btt.
Old 08-09-2010, 12:52 PM   #4
casper
still looking
Old 08-16-2010, 03:35 PM   #5
casper
back to the top.
Old 08-21-2010, 10:22 AM   #6
casper
btt.
Old 08-23-2010, 03:43 PM   #7
Lloyd Tiffany
I have a '34 frame (actually, a rolling chassis.) However, I would be able to use the front and rear-ends myself and the engine. (It's a '37) The chassis was used as a crop duster in Central Calif. There are pieces welded to the frame, 1/2" plates. There is some rust in the rear kick-ups. X-member is nice. Front and rear cross members are there. It looks fairly straight other than the welded-on metal. If I took everything off, I'd want $700 for the bare frame. I'm located in Buellton, CA. Let me know if I can help.
Lloyd
Lloyd Tiffany is offline   Reply With Quote
Old 09-02-2010, 10:11 AM   #8
casper
I tried to buy one, but got shot down, so I'm still looking. Thanks.
Old 09-04-2010, 10:42 PM   #9
hotrodfreak
hotrodfreak's Avatar
I still have a pair of rails minus front 2'+/- $50.
hotrodfreak is offline   Reply With Quote
Old 09-07-2010, 11:44 AM   #10
John Mc
John Mc's Avatar
If you have iterest in a '39 1/2 Ton frame and all, let me know. 815-479-0210
John Mc
Crystal Lake, IL
'39 1/2 Ton Pickup
'56 Lincoln Capri Hardtop
'77 Lincoln Town Coupe
John Mc is offline   Reply With Quote
Old 09-13-2010, 07:01 PM   #11
casper
btt.
Old 09-19-2010, 09:37 AM   #12
casper
btt.
Old 09-29-2010, 05:32 PM   #13
casper
btt.
Old 10-09-2010, 11:12 AM   #14
casper
btt.
Old 10-16-2010, 10:51 AM   #15
casper
btt.
Old 10-28-2010, 09:47 AM   #16
casper
still looking
Old 10-28-2010, 12:40 PM   #17
buds34pickup
Well,
If you want to come up to MN I have a 34 pickup frame with a stock front axle split arms front cross member is still all there and juice brakes it has a 57 chevy rear using the stock 34 rear spring. The x brace was cut some for brake pedals? The PO removed the center (the mount for the wishbone) of the X frame to put a SBC and hacked it up where the steering box mounts to put a late model steering box in it. I have some frame sections that could be used to repair it. It is a roller. All that for only $800.00....
buds34pickup is offline   Reply With Quote
Old 11-17-2010, 05:51 PM   #18
askynot
If you still have this available, please call Dick at 319-987-2610.
Thanks.
Originally Posted by buds34pickup View Post
Well,
askynot is offline   Reply With Quote
Old 11-19-2010, 10:18 AM   #19
casper
I sold the cab, bed and all the sheet metal. The frame is NO LONGER NEEDED Thanks!
