Old 01-20-2021, 02:00 PM   #1
Bruce_MO
Default 1946 Mercury exhaust system source?
Who has the best exhaust system components for a '46 Mercury? The only place I've found that carries any of the larger pieces is Mac's.
Thanks in advance.
Bruce_MO is offline   Reply With Quote
Old 01-20-2021, 02:21 PM   #2
Zeke3
Zeke3's Avatar
Default Re: 1946 Mercury exhaust system source?
Check with Waldron's, waldronexhaust.com. They do a lot of vintage car exhaust systems.
Zeke3 is offline   Reply With Quote
Old 01-20-2021, 03:46 PM   #3
51504bat
51504bat's Avatar
Thanks in advance.
Red's Headers?
https://www.reds-headers.net/
Old 01-20-2021, 04:44 PM   #4
G.M.
I think Ford pipes will work but need to be lengthend
at the mufflers. G.M.
www.fordcollector.com
Old 01-21-2021, 12:54 AM   #5
bobH
George, along the line of what you posted, I'm curious. My recollection is that the engine in a 46 Merc, sits in the same place as in a 46 Ford, in relation to the firewall and all points rearward. Is that so? And, if so, wouldn't the exhaust system for the Merc be the same as for a Ford? I don't really know, and I'm just speculating...
bobH is offline   Reply With Quote
Old 01-21-2021, 12:37 PM   #6
rustythumb
i think the head pipes are different because the manifolds dump in a different spot.
rustythumb is offline   Reply With Quote
Old 01-21-2021, 01:05 PM   #7
G.M.
I think the Mercury caris longer than the Ford. I had the drive
shaft and rear from a 1948 Mercury and it was 8 or so inches
longer. G.M.
Old 01-21-2021, 04:40 PM   #8
meric42
meric42's Avatar
longer. G.M.
I think you'll find that the extra length is due to shifting the front axle forward, the drive train is the same dimensions on both ford and Mercury.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
http://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 01-21-2021, 07:00 PM   #9
42merc
42merc's Avatar
The added length of the Mercury is forward of the cowel.
The motor and drive train is is in the same location as a Ford. The difference happens with the steering gear, about 4 inches more forward than a Ford, which creates a different interference for the dual side pipe if installing dual exaust.
Single, stock exhaust system with cross over pipe is the same for 42-48 Ford or Merc.
I have a Waldron dual side exhaust pipe for a Mercury if anyone is interested.
42merc is offline   Reply With Quote
