Old 01-07-2021, 08:30 AM   #1
bobl
Default cowl patch
I have a 31 coupe and the bottom of the cowl is basically nonexistent so I have nothing to go by. I have a patch panel and the bead along the bottom ( from A pillar to firewall ) is straight. This is the hard part, trying to explain what I would like to know. Here goes; if you get your eye down and site along the upper bead across the door and across the cowl to the firewall, as you get to the cowl the bead curves slightly in towards the motor and then part way along it bends slightly out towards the tire. Should the bead at the bottom of the cowl (patch panel) follow the same slight curves or is the bead straight from the A pillar to the firewall? Thank you.
bobl is offline   Reply With Quote
Old 01-07-2021, 08:58 AM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: cowl patch
No it has the contour you describe
The better panels (sipe) are closer than the others are
Oldbluoval is offline   Reply With Quote
Old 01-07-2021, 09:09 AM   #3
bobl
Thank you Oldbluoval !
