06-10-2020, 04:21 PM | #1 |
36 ford truck body mount
do these use a rubber cushion or does the wood framing sit on the chassis
06-10-2020, 05:22 PM | #2 |
Re: 36 ford truck body mount
If the cab mounts as the pickup cab, which it should -- the cab rests on the wood and the wood has tar impregnated webbing (1.5 by 3 inches by 1/8th) that are placed at each bolt hole and go between the frame and the wood.
Interestingly, when I took my pichup apart, the webbing was stapled to the wood. Hope this helps. |
06-10-2020, 06:43 PM | #3 |
Thread Tools | |
Display Modes | |
