Old 05-04-2020, 07:53 AM   #1
Magoo2
Default Aluminum radiator
Has anyone installed one of the cheap aluminum radiators advertised on eBay. The overflow tube on mine is cracked inside the filler neck and I have tried various fixes,j b weld, plastic straw liner. Nothing is working. Local radiator repair shop not intrested.
Magoo2 is offline   Reply With Quote
Old 05-04-2020, 08:29 AM   #2
rocket1
Default Re: Aluminum radiator
They call themselves a radiator repair shop? Custom radiator is in south Jersey,they do excellent work.
rocket1 is offline   Reply With Quote
Old 05-04-2020, 09:08 AM   #3
Magoo2
Thanks rocket1 I’ll give them a call
Old 05-07-2020, 07:16 PM   #4
RTPbee81
RTPbee81's Avatar
So I'll bump this back up, has anyone had a good experience with these cheap radiators? Mine is shot, radiator repair specialist told me he would boil out and rod it but given it's been repaired before said I wouldn't be happy and be wasting @$200+ bucks I could put towards a new one. Planning on picking one up next trip to Algonquin, Ill, but these sure look interesting for under $200
RTPbee81 is offline   Reply With Quote
Old 05-10-2020, 01:06 PM   #5
fastroadster
They can't be repaired, and make sure you run 90% antifreeze or it sets up electrelisis and plugs the tubes. Just saying......
fastroadster is offline   Reply With Quote
Old 05-10-2020, 02:02 PM   #6
Step-down
Step-down's Avatar
Have one in my AV8 for couple years all good
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 05-10-2020, 02:42 PM   #7
Vic in E-TN
Look into Berg's Radiator in Bluford, Illinois. I have had good experience with them over the years. Also good experience with the shop in Algonquin, Illinois.
Vic
Vic in E-TN is offline   Reply With Quote
Old 05-11-2020, 08:58 AM   #8
30 Closed Cab PU
Think I read somewhere that if you go with an aluminum radiator using a sacrificial anode that hangs in the radiator is recommended.
30 Closed Cab PU is offline   Reply With Quote
Old 05-11-2020, 09:43 AM   #9
Gil Sissons
We have gone with the Wizard Aluminum Radiators.
No question more expensive.... No question zero problems with them.
The same cannot be said for these import cheapie.
"You get what you pay for"
Gil. NoCal
Gil Sissons is offline   Reply With Quote
Old 05-12-2020, 07:54 AM   #10
eagle
eagle's Avatar
There are past threads on these radiators. Some are very happy, others not so much. Fitment is sometimes a problem. I don't remember any complaints about performance.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 05-12-2020, 08:40 AM   #11
1931 flamingo
1931 flamingo's Avatar
When you go to Algonquin, take your old rad with you to match up with the new alum one, especially bracket mount positions, otherwise the shell won't fit right, in fact, take the shell with you also.
Paul in CT
Old 05-12-2020, 01:26 PM   #12
California Travieso
Send a message via Yahoo to California Travieso
Gil. NoCal
Gil,
The Wizard website shows radiators for 1932 cars but none for 1928 - 1931 cars. Did they stop making radiators for A’s?
David Serrano
California Travieso is offline   Reply With Quote
Old 05-12-2020, 05:56 PM   #13
Synchro909
Synchro909's Avatar
Find another shop unless the fins are coming away from the tubes through age.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 05-12-2020, 06:11 PM   #14
eagle
eagle's Avatar
Try CHR racing. They sell a Model A radiator SHIPPED for $258. Call them and discuss it with them. Let us know how it goes. They build their own, not sure if all of them are their own though. https://chrracing.com/collections/au...minum-radiator
