Old 03-17-2020, 08:10 AM   #1
old31
Default 90 degree oil filter hits oil return pipe
Has anyone run into the problem of the 90 degree oil filter is not sticking out far enough from the block.
What happens is the oil filter hits the oil return pipe and can not be screwed in to the adapter.
The 90 degree I bought on line and the # on the unit is 08002089.
Old 03-17-2020, 08:36 AM   #2
brokenspoke
Default Re: 90 degree oil filter hits oil return pipe
https://www.fordbarn.com/forum/showthread.php?t=273067
brokenspoke is offline   Reply With Quote
Old 03-17-2020, 08:57 AM   #3
old31
Broken, I read that earlier and none of it relates to my issue.
Old 03-17-2020, 10:58 AM   #4
MikeK
MikeK's Avatar
Several filters other than the big, FL-1A that holds .88 quarts of oil will fit the same side mount:
Fram PH7328, 3 5/8D x 3 1/4 H .6quart
Fram PH3614, 3"D x 3 3/8 H .4quart
Fram PH3600, 3"D x 5"H .6quart
If you're not a Fram fan, look up the conversions to another brand.
All these filters will fit either directly on the side cover in place of the FL1A or on the 90 degree adapters.
There has also been some talk on this forum (different thread) concerning the backflow preventer flaps in oil filters. Almost all spin-on oil filters have a "backflow preventer" rubber flap valve of sorts that keeps the oil from draining in horizontal apps. A 90 degree adapter is NOT needed to keep the filter full, but they prevent a big mess on removal, and allow 100% pre-fill when changing filters on the side cover mounts.
The ONLY call to remove or defeat it would be if you were running one of the secondary bypass type filters which generate no pressure into the filter. If your filter feeds from the typical side cover mount with an internal tube to the pump outlet it has significant positive pressure. Removing the "backflow preventer" is actually a hindrance, as 1) pre-filling and installing a new filter is a big mess when you go to spin it on, and 2) if your filter is horizontal it will drain every time the engine is stopped, requiring the engine to run with no oil output until the filter fills.
MikeK is offline   Reply With Quote
Old 03-17-2020, 11:30 AM   #5
katy
katy's Avatar
How about a link to the site?
Old 03-17-2020, 12:05 PM   #6
Y-Blockhead
Y-Blockhead's Avatar
Do you have a picture of your 90° adapter?
The 90° adapter I have is off a Mustang (maybe other models too?) and I use a WIX 51515 filter (already painted black, just peel off label).. It is a tight fit, ~⅛" between filter and oil return pipe. Could your pipe be bent out? Causing it to interfere with the filter?
Old 03-17-2020, 12:27 PM   #7
CarlG
CarlG's Avatar
If your oil return pipe is installed backwards it will stick out further than it should.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-17-2020, 02:30 PM   #8
Y-Blockhead
Would the return pipe even fit backwards? The ends are on two different planes.
Old 03-17-2020, 05:22 PM   #9
Jakneedler
Try using Motorcraft Fl400s
Same thread and gasket size smaller diameter it will clear the return pipe
Jakneedler is offline   Reply With Quote
Old 03-17-2020, 09:38 PM   #10
old31
This just might be the wrong product for the A.
I am using WIX 51515.
Carl I was not aware that the pipe would go backwards. I actually looked at it and thought well maybe I did install it backwards, and looked at the pipe angles and said no, who me, install something backwards.
It needs about another 3/4" more from the oil pipe. Its not the length but the width.
Tomorrow I will reverse the pipe and see what happens.
Engine Oil Filter Adapter 4.0L I6 Jeep Cherokee XJ , ZJ PN 53020080
Old 03-18-2020, 12:16 AM   #11
CarlG
CarlG's Avatar
Old31, I was using the Wix 51515 filter on mine. The 90 degree adapter was a Ford Racing part that I probably bought from Speedway. Don’t remember the part number. I do know that I have a box full of other ones I bought that didn’t work.
When I put an exhaust header on the engine it wouldn’t work so I now have a remote mounted one.
Alaskan A's
Old 03-18-2020, 11:07 AM   #12
katy
katy's Avatar
It appears like the adapter that Y-Blockhead is using sticks out further than the one that old31 shows.
Old 03-18-2020, 02:30 PM   #13
1931 flamingo
1931 flamingo's Avatar
"was a Ford Racing part that I probably bought from Speedway". . " Oil Filter Adapter 4.0L I6 Jeep Cherokee XJ , ZJ PN 53020080"
Methinks the Jeep part is your problem, NOT what filter you're using.
Paul in CT
Old 03-18-2020, 03:53 PM   #14
Dodge
I have the same adapter and used a smaller diameter and shorter filter. Works great.
Dodge is offline   Reply With Quote
Old 03-18-2020, 04:28 PM   #15
Phil Brown
Phil Brown's Avatar
The adapter your using is the Jeep part and if I remember right there only 80 deg not 90
the Ford ones look to stand off a little more also. you can find them on 70's vans and the Mustang II 's that had a V8 if you don't want new
Phil Brown is offline   Reply With Quote
Old 03-19-2020, 07:53 AM   #16
old31
Dodge, what filter are you using that does not hit the drain pipe?
Old 03-19-2020, 10:22 PM   #17
California Travieso
Send a message via Yahoo to California Travieso
Carl,
Where did you mount your remote oil filter?
David Serrano
California Travieso is offline   Reply With Quote
Old 03-19-2020, 10:48 PM   #18
Jack Shaft
Both sizes fit on mine..but an easy cure for yours is the smaller K&N (shown)
Jack Shaft is offline   Reply With Quote
Old 03-19-2020, 11:09 PM   #19
The Master Cylinder
The Master Cylinder's Avatar
Jack, what is the part # on the K&N oil filter you use and what vehicle was it originally used on? Thanks
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 03-19-2020, 11:30 PM   #20
Jack Shaft
Ill have to read it tomorrow..
