01-25-2020, 05:50 PM | #1 |
Crankshaft End Play
How do you check crankshaft end play? I have dial indicator. Should rods be removed first?
01-25-2020, 06:34 PM | #2 | |
Re: Crankshaft End Play
Herm. |
01-25-2020, 06:36 PM | #3 |
You can. Just push or pry the shaft fore and aft. Factory specs are .004” to .007”
It will move easy. |
01-25-2020, 08:11 PM | #4 |
Thanks. I need to check bearing clearances as well. Hopefully my babbit is good.
01-30-2020, 12:16 AM | #5 | |
warrene |
01-30-2020, 02:03 AM | #6 |
Herm. |
01-30-2020, 07:15 AM | #7 |
Checked out at just under .015", about double the maximum tolerance. After pulling rods and pistons I've decided to do full rebuild with new babbit. I aim to put this old truck to work so I want it right. As someone said, the AA needs 100% of the engine just to get out of it's own way.
