Old 05-27-2017, 09:55 AM   #1
JOHN CT
JOHN CT's Avatar
Default Upper hose
I'm just doing a Visual inspection I noticed the upper radiator hose is leaking around the seams? The clamps are tight. I never seen this before. So I guess it's time for new hoses. I'm using the stock hose clamps. I've heard that there's a better clamps I can use. Can you tell me what kind to get.
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 05-27-2017, 10:20 AM   #2
RawhideKid
Thumbs up Re: Upper hose
I use the "Tbolt" clamps without any leaks.
https://www.amazon.com/s/?ie=UTF8&ke...l_3y1r7jfe9v_e
Before Walmart you had to buy a ticket to the fair to see a bearded lady!
RawhideKid is offline   Reply With Quote
Old 05-27-2017, 10:39 AM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Upper hose
Remember those long WRAPLOCK clamps? They're handy for MANY things & you just snip off the excess. They're used a lot, for tieing down Brake Lines, I'm sure you've seen them.
Original clamps are a PAIN, at times! Chief said, "Sometimes Baling wire wurks BETTER"!!---LOL--He wasn't Kidding, I've seen him wrap 4 turns around a hose & TWIST the ends together, for a leak free connection.
Bill Nodrip
"THE ASSISTANT GURU OF STUFF"
Old 05-27-2017, 12:22 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I only use original clamps and never had a leak.
I've also never seen a hose leak at the seams like in your picture.
Old 05-27-2017, 02:24 PM   #5
George Miller
George Miller's Avatar
I,m with Tom I have never had a leak with original clamps. Maybe some one used a old hard hose.
George Miller is offline   Reply With Quote
Old 05-27-2017, 02:59 PM   #6
JOHN CT
JOHN CT's Avatar
I've never seen this before either. Are all hoses from the model a supply houses made this way? I just don't understand how they would make (I think it's rubber) hoses with seems in it. I should have taken a better picture it's leaking so bad that there's a A puddle on side of the timing cover. This is what we get with aftermarket foreign parts.
31 Tudor
66 Bonneville
Old 05-27-2017, 06:45 PM   #7
1931 flamingo
1931 flamingo's Avatar
How old is that hose??
Paul in CT
Old 05-27-2017, 07:23 PM   #8
2manycars
2manycars's Avatar
The reproduction hose clamps come in two types: Cheap Chinese junk, and quality reproductions. Some suppliers sell both. As expected, the quality reproductions cost more than the Chinese junk.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 05-27-2017, 07:58 PM   #9
JOHN CT
JOHN CT's Avatar
Paul in CT
I guess the hose is about 10 years old. I have all of paper work on the car in a file but the file is so thick. It would take a forever to find it.
31 Tudor
66 Bonneville
Old 05-27-2017, 08:18 PM   #10
BILL WILLIAMSON
I've seen Guys OVERTIGHTEN original type clamps & "PUCKER" up the hose & it'd leak like my Dog peeing!
Buster T.s' Dad
Old 05-27-2017, 09:14 PM   #11
Tom Wesenberg
Vaseline on the inside of the hose clamps will help prevent bunching of the rubber hose.
I also give the inside of the hose a light coat to help it slip on easier.
Old 05-27-2017, 09:28 PM   #12
HammerSaw
Permatex Permashield Gasket Dressing & Sealant works well. It does not harden and the hose is easy to remove at a later date. It is also fuel resistant.
HammerSaw is offline   Reply With Quote
Old 05-28-2017, 10:25 AM   #13
Anteek29
Anteek29's Avatar
HammerSaw...thanks for the Permashield tip!
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
