Old 09-17-2015, 07:19 PM   #1
1955cj5
1955cj5's Avatar
Default Oil Filter?
Does anyone use an oil filter, either full-flow or bypass?
I think I like the Snyder's style that replaces the timing side cover....just because it looks like a neat installation...
http://www.snydersantiqueauto.com/oil-filter-kit-2054
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 09-17-2015, 08:45 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Oil Filter?
I run a couple of those filters - work fine.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 09-17-2015, 09:14 PM   #3
Ron W
Ron W's Avatar
Looks like a good chance to spill oil! Ron W
Ron W is offline   Reply With Quote
Old 09-17-2015, 09:24 PM   #4
1955cj5
1955cj5's Avatar
Oh but I always have a catch pan under the old pickup!
Old 09-18-2015, 03:25 AM   #5
updraught
updraught's Avatar
Does that sort of filter increase the oil pressure? Well, where the oil guage goes anyway.
updraught is offline   Reply With Quote
Old 09-18-2015, 03:38 AM   #6
Bob-A
Bob-A's Avatar
Thumbs up Re: Oil Filter?
I run the full-flow valve cover filter on my 29 roadster with the original "A" motor. And on my 31 roadster with a "B" block I run the by-pass filter. Any filter is better then no filter! Yes, there is some oil spillage when changing the filters, but it is minor.
Bob-A
Bob-A is offline   Reply With Quote
Old 09-18-2015, 08:49 AM   #7
31Tudor
31Tudor's Avatar
I would think if anything it would decrease the oil pressure. The oil only has one way to go and that is up into the valve chamber to be distributed. With the filter you are spilling oil out of that area and sending it to the oil filter instead of up into the valve chamber. Giving the oil another outlet, would reduce pressure.
31Tudor is offline   Reply With Quote
Old 09-18-2015, 09:26 AM   #8
JohnLaVoy
JohnLaVoy's Avatar
When we tested the various options several years ago we found the valve cover unit was, in our opinion, the best of the ones out there.
JohnLaVoy is offline   Reply With Quote
Old 09-18-2015, 09:44 AM   #9
1955cj5
1955cj5's Avatar
Bratton's shows a similar filter kit, but without the 90° adapter....the adapter seems like a good idea....did you get it along with the rest of the kit or separately?
http://www.brattons.com/product.asp?...=any&PT_ID=all
Old 09-18-2015, 10:11 AM   #10
Y-Blockhead
Y-Blockhead's Avatar
The Bratton's "Kit" is made by Mike's (cheaper) and yes the 90° adapter is a separate item
Old 09-18-2015, 10:40 AM   #11
Ed Pitts
Ed Pitts's Avatar
Another option. Ed
Ed Pitts is offline   Reply With Quote
Old 09-18-2015, 03:33 PM   #12
updraught
updraught's Avatar
I assumed it sends all the oil thru the filter??
Old 09-18-2015, 03:40 PM   #13
Curly
My oil pressure was running at 7 pounds before oil filter. Now it is at 12 pounds.
Curly is offline   Reply With Quote
Old 09-18-2015, 08:56 PM   #14
1955cj5
1955cj5's Avatar
Did the 90 ° adapter come from Mike's also? I can't find one in the online catalog...
Randy
Old 09-18-2015, 10:45 PM   #15
Y-Blockhead
I believe the 90° adapter is made by Ford Racing. http://www.summitracing.com/parts/fm...-a50/overview/
IF you can find one, most '56-'64 Ford Big trucks with the Y-Block engine (292) had a 90° oil filter adapter stock in order to clear the steering box.
If you have a truck bone yard around you may be able to find one cheap.
Old 09-19-2015, 02:22 PM   #16
hardtimes
hardtimes's Avatar
Originally Posted by Ed Pitts View Post
Another option. Ed
Hey Ed,
Hm, nice option , but looks to be 'below' block...how/what fastened to
Another option:
hardtimes is offline   Reply With Quote
Old 09-19-2015, 07:10 PM   #17
waxhead
waxhead's Avatar
Originally Posted by hardtimes View Post
Hey Ed,
Another option:
Looks good Hardtimes. Is that yours??
waxhead is offline   Reply With Quote
Old 09-19-2015, 11:05 PM   #18
Ed Pitts
Ed Pitts's Avatar
[QUOTE=hardtimes;1159210]Hey Ed,
I made a bracket that attaches to two of the oil pan bolts and the assembly then bolts to the bracket. Gets the filter down and out of the way. Ed
Old 09-19-2015, 11:28 PM   #19
40 Deluxe
Has anyone cut open their used filters to see what, if anything, was trapped in the filter? I'm of the opinion that a filter only works on a newly rebuilt engine to trap filings and grindings that the rebuilder didn't bother to clean out during the rebuild process. Most of the dust inhaled through the carb that works its way into the crankcase is under 10 microns, too small for the filter to catch.
Old 09-19-2015, 11:55 PM   #20
hardtimes
hardtimes's Avatar
Hey waxhead,
Yeah, that is the B in my driver, '30 roadster...full flow and no spill !
Plus , as you can see, a threaded opening for the oil gage. Nice unit. Haven't seen another like it, but would like to buy another. Only problem with it, is that it blocks use of the B fuel pump..bummer.
