Old 09-05-2015, 12:38 PM   #1
frank long island
frank long island's Avatar
Default up from a long nap
started a project 20plus yrs ago 64 ford f 250 4x4 352 ci with a holly 2 bbl . 44000 org miles replaced accelerator pump points and condenser solenoid and fuel tank with a temp boat tank fired right up smoked for 5 min guess that was marvel oil I had put in 3 weeks ago when we spun it by hand 60 psi for oil pressure no noises my question is he wants to change the timing chain and oil pump thoughts?second the clutch seems to be stuck to pressure plate all linkage is moving any tricks to free it up it will need replacing as i'm guessin
rust flywheel will need resurfacing then its on to body work left door post lower frt seems to be only rot have cab corners but doesn't look like I need them floor was done yrs ago over mounts bed has rot under tail lights gate is good will try to post pictures
frank long island is offline   Reply With Quote
Old 09-05-2015, 01:03 PM   #2
parklane
parklane's Avatar
Default Re: up from a long nap
Put tranny in high gear, and rock truck back & forth. Sometimes it works.
If brains were wire, some couldn't short circuit a firefly
parklane is offline   Reply With Quote
Old 09-05-2015, 01:51 PM   #3
dmsfrr
dmsfrr's Avatar
Originally Posted by frank long island View Post
..... 44000 org miles ..... 60 psi for oil pressure no noises ..... he wants to change the timing chain and oil pump .....
"If it ain't broke don't fix it."
..... with the clutch pedal pushed in.
dmsfrr is offline   Reply With Quote
Old 09-05-2015, 01:53 PM   #4
frank long island
that's what I told him just need it to move while I do the body getting to old to push in and out of garage
Old 09-05-2015, 03:12 PM   #5
y'sguy
y'sguy's Avatar
Maybe you know this BUT if it matters 1964 PU's did not come with that engine. just fyi.
y'sguy is offline   Reply With Quote
Old 09-05-2015, 06:35 PM   #6
frank long island
I'm not sure of the year may be a 65-66 round tail lights still talking price on the resto
Old 09-06-2015, 03:40 PM   #7
Ole Don
Ole Don's Avatar
I had a stuck clutch on a Mopar I worked on. I started the engine and warmed it up in neutral. The car was up on four stands, nothing in front of it, big door in the garage open, tires on and blown up. I put it in second gear, and started the engine, then with left foot holding clutch pedal down, worked it up through third and into fourth by tickling the gas pedal. Took it up to a hundred, then mashed the brakes hard. Had to do this three times to break it free. It worked fine after that, quiet, no binding, no grabbing.
Ole Don is offline   Reply With Quote
