03-15-2015, 05:04 PM | #21 |
Re: Head Studs or bolts, which is better ?
head studs are really no problem to this latest flathead builders, the engine is taken apart maybe every year or every other year, the studs do not have enough time to really corrode enough to seize to the head, especially if the stud is sealed at the block, if no water can weep up the stud there will be no corrosion
03-19-2015, 12:10 AM | #22 |
I see many blocks with cracks around some of the stud holes. Are bolts safe in those holes?
03-19-2015, 09:59 AM | #23 | |
If you used a bolt in the same hole you would torque it before the permatex set. |
Thread Tools | |
Display Modes | |
