03-05-2014, 11:11 AM | #1 |
Jim Garner
What is the recommended lubricant for a 1931 Vacuum windshield
motor? I read some where to use brake fluid. Is this a good lubricant? |
03-05-2014, 12:26 PM | #2 |
Re: Jim Garner
You will get more/better response if you have your specific question in the title, such as:
What Lubricant for Vacuum Wipers? Also it makes the thread much easier to find in the future. You can change it, but I'm not sure how. What is the wiper made from? My 1950 Studebaker has a leather seal for the wiper and I used ATF on it back in 1970. Last edited by Tom Wesenberg; 03-05-2014 at 01:24 PM. |
03-05-2014, 12:44 PM | #3 |
Re: Jim Garner
The best is to take it apart and check the condition of the flapper seal and re lube with Vaseline.
Other than that, and thin oil will do no harm. Squirt it in and move the wiper by hand while doing so.
03-05-2014, 12:47 PM | #4 |
Re: Jim Garner
Neats foot oil
03-05-2014, 12:50 PM | #5 | |
Re: Jim Garner
MIKE |
03-05-2014, 01:04 PM | #6 |
Re: Jim Garner
03-05-2014, 01:29 PM | #7 | |
Re: Jim Garner
The main thing is it makes it easy to find when using the search feature if details are in the heading. |
03-05-2014, 01:44 PM | #8 |
Re: Jim Garner
Brake fluid may swell the material on the inside and help the wiper work better. I remember back in the day I poured brake fluid in my powerglide to swell the rear seal and slow the leak. It worked fairly good for a while. I've never tried it on a windshield wiper motor. It probably won't hurt unless the brake fluid gets on the paint.
03-05-2014, 01:49 PM | #9 |
Re: Jim Garner
Thanks for the information lubricating my vacuum wipers.
Jim |
03-05-2014, 02:04 PM | #10 |
Re: Jim Garner
i wouldn't use brake fluid
i would call one of the wiper guys listed on the top of the page in the sticky and ask |
03-05-2014, 02:38 PM | #11 |
Re: Jim Garner
Neatsfoot oil.
03-05-2014, 02:44 PM | #12 | |
Re: Jim Garner
As a younger guy, I used Vaseline with good results (depended on cleanliness of motor). Now neatsfoot oil would be my choice if I could get it conveniently. |
03-05-2014, 07:05 PM | #13 |
Re: Jim Garner
03-05-2014, 08:10 PM | #14 |
Re: Jim Garner
I have had brake fluid remove paint in the past. I would not use it near a painted surface.
--------------------------------------------------------------- If it was easy everyone would be doing it /Tony |
03-05-2014, 09:44 PM | #15 |
Re: Jim Garner
Here is a great link from a previous thread on the subject. I used this and it brought mine back to life. http://modelabasics.com/wiper.htm
03-07-2014, 01:27 PM | #16 |
Re: Jim Garner
Thanks guys,
This has been educational. Jim |
