Old 12-28-2020, 12:21 AM   #1
10gaugemag
Default Edmunds manifold, Twin Stromberg 97 carbs
Found this critter while cleaning in my grandpas basement yesterday.
Are these sought after by Flathead enthusiasts?
Also what's the bolt/stud on the end of the manifold for?
Thanks in advance for any advice.
10gaugemag is offline   Reply With Quote
Old 12-28-2020, 12:24 AM   #2
10gaugemag
Default Re: Edmunds manifold, Twin Stromberg 97 carbs
Old 12-28-2020, 12:25 AM   #3
10gaugemag
Old 12-28-2020, 05:21 AM   #4
Mart
Mart's Avatar
Hello. Yes, that would be something a flathead enthusiast might want. The Stromberg carbs are also something that people go for. The big stud at the front is where the generator attaches.
Mart.
Old 12-28-2020, 12:06 PM   #5
10gaugemag
Wonder if the barb fitting tapped in the top between carbs is a factory job?
Old 12-28-2020, 12:37 PM   #6
tubman
tubman's Avatar
I have several Edmunds manifolds, and that's how they typically hooked up the windshield wipers. That manifold is different from most Edmunds dual manifolds in that the carburetors appear to mounted further forward than usual. To use it, you will probably need a special generator bracket. It does look like an alternator might fit, though. Finally, the road draft tube and oil filler tube openings in the front make that for the later "8ba" engines ('49-'53).
While that setup is desirable (especially with those carburetors), it is not a sought after rare collectible.
Old 12-28-2020, 01:50 PM   #7
Mart
Mart's Avatar
The carbs may be mounted further forward because it is an 8BA type, which can typically have the generator further forward to line up with the belts.
Old 12-28-2020, 02:21 PM   #8
10gaugemag
Would a better pic of full length tell you more if it does in fact have carbs mounted forward?
Old 12-28-2020, 02:39 PM   #9
tubman
tubman's Avatar
That would help. The Edmunds 8BA dual manifolds I have seen have the "Edmunds" script between the front of the manifold and the front carb, not between the carbs like yours. These will allow the generator to be mounted in the conventional position. I couldn't be sure about yours unless I measured it or tried a generator, but I don't think a generator would fit. Edmunds made several varieties of 8BA dual manifolds including a "Super" for 4 bolt carbs, so it's hard to know. Here's a picture of a more common Edmunds 8BA dual. Note the difference in the distance between the front carb and the generator mount.
Old 12-28-2020, 02:46 PM   #10
V8 Bob
V8 Bob's Avatar
The first regular dual I ran on my '51 was an Edmunds like the one pictured above. The can ran OK, but the carb placement and spacing just looked odd imo, and like no other regular 8BA I've ever seen. I eventually sold it and installed an Edelbrock regular dual that has "normal" carb placement and spacing. I remember the buyer was Charlie Price of Vintage Speed who was collecting Edmunds products at that time.
Old 12-28-2020, 05:39 PM   #11
aussie merc
aussie merc's Avatar
definitely good swap meet material if priced correctly
aussie merc is offline   Reply With Quote
Old 12-28-2020, 09:07 PM   #12
10gaugemag
Here ya go.
Old 12-28-2020, 09:09 PM   #13
10gaugemag
Old 12-29-2020, 07:38 AM   #14
flatford8
flatford8's Avatar
Talking Re: Edmunds manifold, Twin Stromberg 97 carbs
I think this like the one Tubman posted with 94’s....... Mark
File Type: jpg F67C5AD8-B2AC-408F-89F5-0F34FBB59C04.jpg (52.9 KB, 63 views)
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 12-29-2020, 07:38 AM   #15
flatford8
flatford8's Avatar
I took the picture while going down a very steep hill....... Mark
Billy Joe Shaver
Old 12-29-2020, 07:47 AM   #16
V8 Bob
V8 Bob's Avatar
Now that I clearly see the manifold, it has the overall design and carb placement like most regular 8BA duals. The picture of Tubman's is the odd one I described in my previous post.
Old 12-29-2020, 11:03 AM   #17
hop up
hop up's Avatar
The intake is a later one and 49-53 had a generator mount and strap as pictured is needed to run a gennie on the 49-53. This would move it out a bit to fit your generator. Thats a nice setup and worth a few bucks as the carbs are desirable 1935 1936 1937 large logo 97 carb
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
Old 12-29-2020, 11:08 AM   #18
tubman
tubman's Avatar
The O/P's manifold seems to have less than 6" clearance between the generator mount and the front carb. I don't have anything here in Florida to measure, but I don't think that's near enough for a regular Ford generator. It is probably plenty for an alternator.
"V8 Bob" - It's odd, but all of the 8BA Edmunds dual manifolds I have seen look like the picture I posted. It's why I have always referred to the Edmunds as "the ugliest manifold in existence".
I just noticed the 97's match; that's a plus as well.
Old 12-29-2020, 11:35 AM   #19
hop up
hop up's Avatar
As you see in the picture the generator will be moved forward and clears the carburetor. This is on a 53 Mercury motor thin belt gennie and with the strap that hold the generator you move it more forward with the twin belt system. The center line for the belt is 3.250 that is on the water/generator and second belt center line is 3.750 running the fan/waterpump. This is why it works as it moves the generator forward to run water pumps.
Old 12-29-2020, 11:59 AM   #20
hop up
hop up's Avatar
49-53 generator with strap mount and early edmunds with early style gennie
