03-01-2020, 08:42 AM | #1 |
Has anyone converted a 12V heater to 6V?
I'm not fond of the idea of cutting a hole through the firewall for a manifold heater. If the hole was already there, I would probably have a different opinion, but there isn't already a hole.
My car is 6V positive ground. So, I've searched for a 6V water heater for a while. I would think that a number of 6V cars are still around, and I'm surprised there doesn't seem to be a 6V solution. I've seen Arvin heaters on eBay, but I'm guessing that they are going to need lots of "tender love and care" to get them to work (because most of them are probably already worn out before they landed on eBay). This seems to be about the smallest footprint for a heater that I've found, but it is 12V. I'm guessing that this heater is also negative ground. https://www.speedwaymotors.com/Speed...BTU,73715.html Has anyone converted this heater (or a similar heater that can still be purchased new today) from 12V to 6V positive ground? |
03-01-2020, 09:43 AM | #2 |
Re: Has anyone converted a 12V heater to 6V?
Using a hole saw on your firewall is a whole lot easier than what you are thinking of doing. I hope you realize there is also a cover that goes over the hole when the heater is removed. When all said and done it is hardly noticeable.
03-01-2020, 09:57 AM | #3 | |
I'm wondering, can you use a 6v to 12v step up converter. Your just looking to run the fan, correct?? May be easier than changing the heater from 12v to 6v.
The Master Cylinder Enjoying life at the beach in SoCal... Last edited by The Master Cylinder; 03-01-2020 at 10:08 AM. |
03-01-2020, 09:59 AM | #4 |
If you have the talent and the time, and just cash to spend, look at :https://www.classicparts.com/1947-54...ctinfo/68-005/
03-01-2020, 10:51 AM | #5 | |
Hmm.... That’s correct. I’m only needing to run the fan at 6V. Can anyone recommend a step up converter? Sent from my iPhone using Tapatalk |
03-01-2020, 11:12 AM | #6 |
03-01-2020, 11:42 AM | #7 |
Snyders sells a small 7" square unite with 6 volt fan.
https://www.snydersantiqueauto.com/P...earchByKeyword |
03-01-2020, 12:30 PM | #8 | |
03-01-2020, 01:14 PM | #9 | |
The Master Cylinder Enjoying life at the beach in SoCal... |
03-01-2020, 03:08 PM | #10 |
I am having same thoughts. Working on a AA truck. I intend to drive it pretty much year round and toying with the heater idea. I will need to replace a cracked exhaust manifold so I’m not opposed to the manifold heater but wondering how effective it is? My firewall doesn’t have the hole yet either. I have thought about a hot water heater. There is another thread about this here too.
03-01-2020, 04:20 PM | #11 | |
Thanks for the link. I thought I checked Snyder’s earlier. I just have missed them. Does anyone have any experience (pictures) for this model? I wonder what the blower switch looks like and where it would mount. Sent from my iPhone using Tapatalk |
03-01-2020, 04:23 PM | #12 | |
03-02-2020, 12:43 PM | #13 | |
The converter will also need to be capable of delivering the current required by the motor, listed on its label. The heater may work if you simply connect -6V to the 'high speed' wire and ground the frame, tape off the low speed wire. The motor will run at half speed, but direction of rotation depends on motor type. My hunch is it will still blow and not suck. |
03-02-2020, 02:28 PM | #14 |
PM sent
Paul in CT |
03-03-2020, 10:32 AM | #15 | |
03-04-2020, 10:50 AM | #16 |
03-04-2020, 11:07 AM | #17 |
Oops, I guess I had my thinking cap on backwards.
03-05-2020, 09:39 AM | #18 |
shew01 check your inbox.
