06-03-2019, 04:36 PM | #1 |
Lowering the back of a Pick Up
Hi all, about a year and a half ago, I posted a question about how to lower the back end of a pick up.
I have a 31 Roadster P/U and the back end is too high. I received a few replies most saying take 2 leaves out of the rear spring, but not saying which ones. Then Jim Brierley replied saying install a Model T spring. So I took his suggestion, got a T spring, cleaned it, nosed the ends, and sprayed dry graphite on the bottom of each leaf. Just finished installing it this morning. WOW what a difference, the T spring gave me a 2" drop, and the bed looks level! Thanks Jim, Herb Neumann Concord CA |
06-03-2019, 05:15 PM | #2 |
Re: Lowering the back of a Pick Up
I have the same truck. I just run a roadster spring and it looks fine.
Charlie Stephens |
06-03-2019, 05:52 PM | #3 |
06-03-2019, 08:57 PM | #4 |
Should have left the rear end high. We know cars get better fuel economy going downhill.
06-03-2019, 09:14 PM | #5 |
06-04-2019, 06:36 AM | #6 |
06-04-2019, 11:06 AM | #7 |
You're welcome, glad you like it! Tom and 40 deluxe brought up some good points!
06-05-2019, 12:14 PM | #8 |
Let's see a before and after pic
06-05-2019, 03:42 PM | #9 |
I have a T rear spring for cheap.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
06-05-2019, 08:29 PM | #10 |
Hi, I am building a model a boat tail speedster, what model t spring have you used the early or the late, also is it hard to spread the spring to fit the model a axle, I would like to drop it 4" if possible, my body weighs about 350lb... thanks, Jim
