Old 08-18-2017, 02:59 PM   #1
marc hildebrant
marc hildebrant's Avatar
Default Stone Guard Install Question
Group,
When you install the Stone Guard support bracket to the radiator shell, do you have the end of the bracket under the headlight grommet next to the radiator shell or between the headlight cable and the grommet ?
Marc
marc hildebrant is offline   Reply With Quote
Old 08-18-2017, 04:26 PM   #2
ModelAMike1930
ModelAMike1930's Avatar
Default Re: Stone Guard Install Question
I installed both of mine under the grommet.
ModelAMike1930 is offline   Reply With Quote
Old 08-18-2017, 05:15 PM   #3
29spcoupe
29spcoupe's Avatar
I installed mine the same.
29spcoupe is offline   Reply With Quote
Old 08-18-2017, 05:38 PM   #4
JOHN CT
JOHN CT's Avatar
Me 2 under the grommet.
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 08-18-2017, 05:43 PM   #5
Synchro909
Synchro909's Avatar
Ditto
Old 08-18-2017, 05:45 PM   #6
1931 flamingo
1931 flamingo's Avatar
I think I cut the grommet and removed enough so the bracket fit in.
Paul in CT
