03-29-2016, 05:42 PM | #1 |
Restoration question,..bolt finish "S"..
I have this question about the bolt finish "S" from the "Standard Hardware"
book. The "S" in the book states that it is "Plain",.. What finish/color is "plain"? 1. Is it after the fastener was made,..bluish/black for Steel? 2. Were the parts "tumbled" too a bright/flat Steel finish? 3. Some kind of acid bath finish,..semi-bright with rust spots? I'm sure there are other combinations. NO guessing,...I'd like to hear from some of the fella's of the Judging Standards committee that knows.. Thanks, Dudley |
03-29-2016, 05:59 PM | #2 |
Re: Restoration question,..bolt finish "S"..
Plain is unfinished not blued not blacked.
03-29-2016, 06:04 PM | #3 |
03-29-2016, 06:23 PM | #4 |
03-29-2016, 06:25 PM | #5 |
S = Plain
S1 = black enamel paint S2 = Raven (Phosphate & Oil) S3 = Raven finish with black painted head only S4 = Raven (Phosphate & Oil) and black paint S5 = Copper plate S6 = Nickel Plate S7 = Cadmium plate S8 = Zinc plate S7-8 = Cadmium-Zinc S9 = Zinc plate (Bright) S10 = Tinned S11 = Copper Coat S12 = Lacquer to match trim S13 = Chrome plated (Interior Parts) S14 = Nickel plate - Butler finish S15 = Black Oxidized S16 = Lead plate S18 = Case hardened S20 = Cement Coat S21 = Lacquer for identification S23 = Rustless (Stainless) steel - head polished S26 = Cadmium or zinc plate and enamel S27 = Screw blank S28 = Sterile coating |
03-29-2016, 07:21 PM | #6 |
Think of an original bolt or nut that is new. It is plain steel and smooth. It is different than if it was plated or bead blasted. It is more like if you wire brush it. In the interest of preservation, it is acceptable to coat the unfinished fasteners so they will not rust. You just don't want to make them look like they have been cad plated. They should all match on the vehicle. |
03-29-2016, 10:33 PM | #7 | |
A light (thin) coat of clear satin as a preservative, otherwise the plain steel will rust. You don't want these parts to be shiny. They should look like they have no coating on them at all, like they are plain steel.
03-30-2016, 06:43 AM | #8 |
03-30-2016, 07:43 AM | #9 |
03-30-2016, 08:29 AM | #10 |
I think S is plain steel, like stated above several times. I usually do what Jim Cannon does, except I spray a matte or flat clear on the plain steel parts, either before I install them or carefully after installation, instead of brushing the clear on. Matte or flat clear can be purchased at hardware stores in an aerosol spray can.
Rusty Nelson |
03-30-2016, 06:53 PM | #11 |
I did a test run on a Cad / Zink flat washer,..here is the photo..
Standard washer on the left. The washer on the right was in the acid bath for a half hour. I didn't touch the left side, the right side I brushed with a SS tooth brush,...is this what I'm after? |
03-31-2016, 01:56 PM | #12 |
Thanks too everyone for the help!..........including you, Mitch.....lol
03-31-2016, 06:29 PM | #13 |
