09-23-2021, 11:58 AM | #41 | |
Re: Engine Identification '34 Ford
FORD2.jpg FORD3.jpg FORD4.jpg |
09-23-2021, 12:25 PM | #42 |
Thanks for the informative photos.
With the notable exceptions of the horn, ignition coil, and carburetor, everything looks to be of Ford origin. One Ford item that has been replaced over the years with an earlier version is the generator. It has what appears to be a '32 generator with a stamped steel front cover/support instead of the late '33-'34 version with a die cast front cover and a vented back cover. I assume that your wanted list includes an air cleaner with a modern element as running it without one will hasten the time when the engine will require rebuiding. |
09-23-2021, 02:53 PM | #43 | |
09-23-2021, 04:45 PM | #44 |
Once again, IF “authenticity” and “as Henry built it” the ultimate goal, you are also missing engine tins/splash aprons pictured. Not uncommon them
missing, most don’t know as they aren’t there to begin. |
09-24-2021, 06:32 AM | #45 |
I stand corrected, DavidR astutely pointed out...my quick glance at the left side shows your tin appears bent downward. Your right pan is clearly there. my apologies on that detail
