Old 06-08-2021, 02:46 AM   #1
Graham Freeman
Default 1933/34 fuel gauge air line routing thru firewall.
Just want to verify that the fuel gauge airline goes thru the same hole in the firewall on a 33/34 as the wiring harness, temp sender etc?
The logical place appears to be with the speedo cable but this may not be correct.
Thanks
Graham
Graham Freeman is offline   Reply With Quote
Old 06-08-2021, 03:14 AM   #2
DavidG
DavidG's Avatar
Default Re: 1933/34 fuel gauge air line routing thru firewall.
Originally, the '33-'34 V8 fuel gauge air line was routed through the same hole in the firewall as the main wiring harness.
Old 06-08-2021, 04:46 AM   #3
Graham Freeman
Thanks David.
