Old 12-07-2019, 10:58 AM   #1
37 Coupe
37 Coupe's Avatar
Default Which 1931 hub cap to buy.
I would like to buy a set of six to replace the ones that were probably put on in the sixties,surface rust.Just confused of all the options.Bratton's shows some that are reasonable enough some are very expensive.Some say flat some say domed at Ford script.Are all Vintique?I really just want a good quality set that will stay on and stay shiney.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 12-07-2019, 11:17 AM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Which 1931 hub cap to buy.
I prefer the stainless steel 30-31 hub caps without the steel inner liner . I can usually straighten the stainless steel caps without the steel inner lining when they get bent . I used the domed at the script hubcaps because I think they are more like original .
Old 12-07-2019, 11:25 AM   #3
The Master Cylinder
The Master Cylinder's Avatar
Purdy you crazy Dude. Going around bending your hubcaps all the time...
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 12-07-2019, 12:35 PM   #4
Purdy Swoft
Sometimes it can happen .
Old 12-07-2019, 03:35 PM   #5
figment
A&L have the really nice stainless steel hub caps . They can sometimes pass fine point . Price might be a little higher but the quality is top shelf . Norm
figment is offline   Reply With Quote
Old 12-07-2019, 04:41 PM   #6
Synchro909
Synchro909's Avatar
Side tracking a bit here but I recently changed the wheels on my '28 Tudor to 19" for the extra road grip. It is a driverm not a show car but when I did, I fouind that the rear hub caps were pushed nearly off the wheel by the axle. The hubs tighten as they should with no extra thread showing so I can't see that they are not going on far enough. The brakes don't make any scraping sounds and work as they should so the hubs are not too far on.
Are some repro hub caps made flatter than others? Mine are a few years old by now but those wheel haven't been used.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 12-08-2019, 10:46 AM   #7
old31
Yep, that happens when Purdy runs into curb stones. Purdy needs to install those 50's curb feelers on both bumpers.
https://www.amazon.com/Superior-26-6...ustrial&sr=1-3
Old 12-08-2019, 12:13 PM   #8
duke36
I use the $10 '30 st. steel types which look close to originals. Easy to re buff except as stated the steel liner makes it difficult to knock out dents. At the cheaper price get a couple extras as back up.I only bend a few tabs over and use clear silicon to help secure, especially for the spares wheels to access the center bolt. The gaskets offered by vendors haven't worked for me.
duke36 is offline   Reply With Quote
Old 12-08-2019, 12:40 PM   #9
37 Coupe
37 Coupe's Avatar
Good information Thank You and I also wondered about the gaskets.
Old 12-08-2019, 06:28 PM   #10
Purdy Swoft
Actually I've never ran into the curb . Sometimes small dents can happen on the thin stainless hubcaps . If or when it happens , I don't try to beat the dent out . I turn the cap over on a smooth hard surface and rub the dent out with a piece of wood from the back side . If the hubcap is badly bent, the dent can't be rubbed out . I bend the tabs in a V shape on my hubcaps so they can be removed and installed like modern hubcaps . Hub caps are cheap and may not be worth the trouble of trying to straighten .
