Old 01-17-2019, 11:07 AM   #1
Gerald cook
Default Dropped axel
I need advice on putting a drop axel under my 29. The forum is where I always get sound advice. I have mechanical brakes which I want to keep I have most of the parts for the change the only thing I’m unsure of is the amount of axel drop for this change 2” or 4” ? And the front spring mono leaf or reversed eye. Thanks Jerry
Gerald cook is offline   Reply With Quote
Old 01-17-2019, 11:10 AM   #2
denis4x4
denis4x4's Avatar
Default Re: Dropped axel
I went with a 2" dropped stock axle and a reverse eye spring
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 01-17-2019, 01:39 PM   #3
Jim Brierley
A reverse-eye spring will lower the car about 1&1/2", so get the axle that will lower it as you want. There may be some alignment issues with the brake mechanism, the axle will be lower than before in relation to the king pin. A spacer can be made.
Jim Brierley is offline   Reply With Quote
Old 01-18-2019, 12:24 AM   #4
Chris Haynes
Chris Haynes's Avatar
Did Axel Rose have a dropped axle?
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 01-18-2019, 10:14 AM   #5
zzlegend
zzlegend's Avatar
My avatar picture has a 4" dropped axle and a stock spring. You will also have to make some stands for your brake actuator if you are going to run mechanical brakes. Just my 2 1/2 cents.
zzlegend is offline   Reply With Quote
Old 01-18-2019, 11:20 AM   #6
CarlLaFong
CarlLaFong's Avatar
Axl Rose might have
CarlLaFong is offline   Reply With Quote
Old 01-18-2019, 02:39 PM   #7
noyo55
I have a 4" drop axle with a reversed eye spring. make sure that when you have the axle dropped it also needs to be stretched to the stock width. If not then you end up shortening the tie rod.
noyo55 is offline   Reply With Quote
Old 01-18-2019, 04:33 PM   #8
wensum
wensum's Avatar
Lots of problems with the tie rod even with a 1.5" drop unless you can use later stub axles for which dropped steering arms are available. There appear to be no dropped steering arms made for the Model A stub axles?
wensum is offline   Reply With Quote
