Old 08-30-2021, 05:31 AM   #21
Graham Freeman
Default Re: 34 speedo removal
Dean,
Why can you not make a stud up welded to a piece of flat and epoxy that on the back of the dash in the correct place.
Would not disturb any paint or wood graining on the other side?
Graham Freeman is offline   Reply With Quote
Old 08-30-2021, 10:10 AM   #22
dean333
dean333's Avatar
Send a message via Yahoo to dean333
That was a thought also Graham.
Tim Carlig
dean333 is offline   Reply With Quote
Old 08-30-2021, 11:54 AM   #23
tubman
tubman's Avatar
I kinda like the duct tape on the other side. Red Green would certainly give it his stamp of approval.
Old 08-30-2021, 11:59 AM   #24
dean333
dean333's Avatar
Like I said guys, the unit is very lightweight and the way it sits in the recess of the opening adds to the support of the one stud.
Tim Carlig
Old 08-30-2021, 02:35 PM   #25
DavidG
DavidG's Avatar
Right up Red Green's alley.
DavidG is online now   Reply With Quote
Old 08-31-2021, 12:53 PM   #26
dean333
dean333's Avatar
The speedo reads about 5-7 mph slow, shows 35 when I’m actually doing 42. Is that a simple one or two tooth adjustment of the pinion position?
Tim Carlig
Old 08-31-2021, 01:42 PM   #27
Zeke3
Zeke3's Avatar
There is a table in the "Green Bible" that shows the speedometer drive gear needed based on rear axle ratio and tire size.
Zeke3 is offline   Reply With Quote
