Old 08-15-2021, 11:56 AM   #1
Will D
Will D's Avatar
Default Correct gauge wire
What gauge wire is run thru the stock ammeter on 38' ford stock 6v system?
Sometimes, ingenuity gets in the way of sense and sanity.
Will D is offline   Reply With Quote
Old 08-15-2021, 08:29 PM   #2
JSeery
JSeery's Avatar
Default Re: Correct gauge wire
I don't have a reference for 38, but several later years call out 10 gauge for pass-thru ammeters.
Old 08-16-2021, 01:54 AM   #3
34fivewindow
34fivewindow's Avatar
10 gauge wire.
34fivewindow is offline   Reply With Quote
Old 08-16-2021, 07:39 PM   #4
Will D
Will D's Avatar
Thanks guys.
Old 08-17-2021, 08:00 AM   #5
jimvette59
jimvette59's Avatar
Just a note Fuse size is to protect the wire size.
jimvette59 is offline   Reply With Quote
Old 08-17-2021, 11:05 AM   #6
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by jimvette59 View Post
Just a note Fuse size is to protect he wire size.
......and...fuses are designed to protect wiring...NOT the device, or load. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-17-2021, 12:11 PM   #7
Will D
Will D's Avatar
Should I be adding a fuse to this wire? It goes from starter solenoid, looped thru ammeter and to starter switch. Any accessory lights I have run direct from the battery thru a fuse and a relay.
Old 08-17-2021, 12:50 PM   #8
ford38v8
ford38v8's Avatar
No fuse.
Alan
Old 08-17-2021, 02:37 PM   #9
JSeery
JSeery's Avatar
The original was not fused. Way later years used a fusible link in the wiring.
Old 08-17-2021, 04:12 PM   #10
Will D
Will D's Avatar
I'm going away from the cloth wire to plastic coated, originality is not huge on the list.... would you recommended adding a fuse for the heck of it or leave it out?
Old 08-17-2021, 04:48 PM   #11
V8COOPMAN
V8COOPMAN's Avatar
Leave the fuse out on that circuit. You DO realize that all wires are not the same. You want a soft-stranded, very flexible automotive-type wire that is not so stiff as to be prone to vibration-induced cracking, like "GXL" wire. DD
T5 W/TORQUE TUBE
Old 08-18-2021, 02:06 PM   #12
rotorwrench
rotorwrench's Avatar
If a buss wire is fused, which is rare in automobiles in the early Ford era, it has to have a fuse and a wire that can carry the rated load of the system. The 1938 was likely still a 25-amp system with a 3-brush generator and a cut out relay but it may depend on whether it is a standard or deluxe model. Voltage regulators and 35-amp generators were in their infancy in 1938. 10 AWG wire would still be a safe bet. A fuse would not be original on a buss wire. Many used circuit breakers instead of fuses for protected circuits.
Old 08-18-2021, 04:35 PM   #13
ford38v8
ford38v8's Avatar
The ‘40 Ford came out with what was called a circuit breaker for the lighting circuits, before which were 20 amp fuses on the earlier models. The so-called circuit breaker was actually an intermittent contact buzzer(terminology?) that was said to provide needed headlights at night at intervals spaced close enough to see where the roadway was. The circuit would heat up, overload, trip, cool down, and reset itself at a speed that had it described as a buzzer.
Alan
Old 08-18-2021, 06:46 PM   #14
JSeery
JSeery's Avatar
Yes, but not on the circuit in question.
Old 08-18-2021, 07:10 PM   #15
rotorwrench
They used a bi-metallic strip that would hold connection till it got hot enough to trip. As soon as it cools then the circuit is restored. These type of short stop CBs were used up until recent 10 or 20 years ago in trucks and Harley Davidson motorcycles.
Old 08-18-2021, 08:52 PM   #16
ford38v8
ford38v8's Avatar
That’s good info, and serves to reaffirm that simple, basic technology continues to have value in today’s complicated world.
Alan
Old 08-18-2021, 09:46 PM   #17
VeryTangled
VeryTangled's Avatar
Hi Everyone. Will D, The replacement wire looms for my '35, purchased within the last 5 years, were copper-rubber-cloth. So you can have it both ways, the original look with the accepted safety factor.
The original wiring is just copper-cloth and any of it you have that is 80 years old simply must go away.
-Jeff H
