Old 07-31-2017, 08:39 PM   #1
michael a
michael a's Avatar
Default Starter accessory
Has anyone tried the starting motor accessory that lets you start the car from the ignition lever
Sent from my SM-J700T using Tapatalk
michael a is offline   Reply With Quote
Old 07-31-2017, 09:56 PM   #2
daveymc29
daveymc29's Avatar
Default Re: Starter accessory
Ignition lever? Are you sure? You wouldn't be speaking of the spark advance lever to the left side of the steering column just below the steering wheel would you? There is an accessory called an "upstart."
daveymc29 is offline   Reply With Quote
Old 07-31-2017, 10:23 PM   #3
SeaSlugs
SeaSlugs's Avatar
I've seen it called sparky start as well... I mean if everything is adjusted correctly it should work...just gotta remember to not fully retard the car while enginee is running
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 07-31-2017, 10:44 PM   #4
1955cj5
1955cj5's Avatar
Never used or seen one...
https://www.brattons.com/sparky-start-system.html
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 07-31-2017, 11:38 PM   #5
Y-Blockhead
My Town Sedan had 'parts' of an Up-Start http://www.snydersantiqueauto.com/up-start installed when I bought it. taken off now. I never had all the parts to "try it" and couldn't really see a need for it.
Foot works well for me.
Old 08-01-2017, 02:41 AM   #6
DougVieyra
DougVieyra's Avatar
I did have one of these reproduction "up start", which was a knock off of an original FULTON accessory starter. It did not work well. And I soon took it off.
50 years ago I had an original "DuoTro" dash mounted hand-starter, with built in choke. It worked very well. But was just 'candy', and not a real improvement over the foot starter.
DougVieyra is offline   Reply With Quote
Old 08-01-2017, 07:34 AM   #7
jhowes
I have used this starter accessory for years now. I first put it on when In had a foot injury and couldn't use the foot starter button. It has worked for years now and I never took it off. Jack
jhowes is offline   Reply With Quote
Old 08-01-2017, 07:56 AM   #8
Bruce
Bruce's Avatar
I installed the SparkyStart version on our '30 Woody so my wife would not try to start the car with the spark advanced. It works like a charm. However, she still needs to pull the spark advance lever down ... to turn off the starter motor. One good idea caused another concern. Bottom line, though, we are keeping the gizmo. It works.
Bruce is offline   Reply With Quote
Old 08-01-2017, 08:37 AM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
My looooong leg brace won't allow my foot to get on the BUTTON, I use a looooong Snap-On Screwdriver. Without the rubber pad, it would be useless! It's HARD to do in the DARK. Some things are EASIER, in the DARK--LOL
Bill Awkward
"THE ASSISTANT GURU OF STUFF"
