Old 05-24-2017, 08:16 AM   #1
tinkirk
tinkirk's Avatar
Default back up lights
has anybody ever tried to install backup lights on an A??
Tinkirk/Terry
tinkirk is offline   Reply With Quote
Old 05-24-2017, 08:30 AM   #2
kd4lok
kd4lok's Avatar
Default Re: back up lights
No, but I found recently a small backup light purchase from one of the suppliers in the 80s and never installed.
Installation should be relatively simple if only providing power through an on-off switch.
Bob
kd4lok is offline   Reply With Quote
Old 05-24-2017, 08:39 AM   #3
Hicktick
Hicktick's Avatar
I don't want to know where you go at night and how you park that you would need back up lights .
, My daddy asking about 1972 ,.
Sometimes I want to say ,,You should have bought a Shay.
Hicktick is offline   Reply With Quote
Old 05-24-2017, 09:01 AM   #4
Farrell In Vancouver
Farrell In Vancouver's Avatar
I mounted one on my 31 AA just aft of the pumpkin. Tough to see when reversing in the dark but it work wonders now. Trouble was finding a 3.5" 6 volt lamp to fit the housing I had. A local tractor supply brought one in for me. I mounted a fused switch top of the drivers kick panel with an red light indicator to tell me its on.
Farrell In Vancouver is offline   Reply With Quote
Old 05-24-2017, 09:44 AM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I have stock yellow brake lights. I was driving down a 4 lane road, with traffic lite's thru federal way wash., when so young guy in a ratty old el Camino pulled up and said "every time you brake, your back up lights come on." I just smiled and thanked him.
Old 05-24-2017, 10:42 AM   #6
tinkirk
tinkirk's Avatar
what i have is a couple of mini diode lights that i was thinking of installing down where a spare tire carrier bolt holes are to plug the holes and, wanting to hook up so when i put it in reverse the light come on like the newer junk of today
have not looked at the shifting part of it yet to see where i can install a switch
Tinkirk/Terry
Old 05-24-2017, 11:02 AM   #7
3.6rs
3.6rs's Avatar
Model A's are supposed to be driven forward ...
3.6rs is offline   Reply With Quote
Old 05-24-2017, 11:16 AM   #8
duke36
have one that resembles a small fog lamp mounted on the rear bumper bracket and operated by a toggle switch
duke36 is offline   Reply With Quote
Old 05-24-2017, 11:41 AM   #9
SeaSlugs
SeaSlugs's Avatar
FYI gotta watch some states - once you add a feature (turn signals, backup lights, seatbelts, etc) not originally from the factory you must abide by current laws and vehicle codes(IE burned out bulbs, not using turn signals, seat belt laws)
I think backup lights and maybe a soft beeper on an AA is a great idea. A hidden switch with a warning light/beeper that they are on is the simplest idea as well.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 05-24-2017, 12:07 PM   #10
Patrick L.
Patrick L.'s Avatar
Yep, thats part of the reason why I switched to all red.
Old 05-24-2017, 12:08 PM   #11
Patrick L.
Patrick L.'s Avatar
And here Henry wasted all that time and money having a backwards gear put in his cars.
Old 05-24-2017, 12:34 PM   #12
30 Tudor
30 Tudor's Avatar
Seems like a good idea,the shift tower is set up so the detent rod for reverse would activate a switch screwed into the end of the casting.
Seems like I have a distant memory of some automatic trans with such a switch on them, maybe a Chrysler TF-6 or TF-8 ,,,,or some ancient cast iron thing?
30 Tudor is offline   Reply With Quote
Old 05-24-2017, 12:37 PM   #13
SeaSlugs
SeaSlugs's Avatar
modern manual trans missions use a ball switch plunger switch setup. screws into the side of the trans and has 2 wires commin out.
Old 05-24-2017, 12:59 PM   #14
CHuDWah
CHuDWah's Avatar
And even a dedicated pedal on the previous model
CHuDWah is offline   Reply With Quote
Old 05-24-2017, 12:59 PM   #15
tinkirk
tinkirk's Avatar
that is kind of my thoughts just need to find the right spot to drill and tap an access hole
Tinkirk/Terry
Old 05-24-2017, 01:34 PM   #16
30 Tudor
30 Tudor's Avatar
That sounds like the ticket.
Another item for the salvage yard hunt.
Old 05-24-2017, 02:23 PM   #17
CarlG
CarlG's Avatar
I have back-up lights installed on my pickup. They come on when the transmission is in reverse and the key is on.
Transmission is an RTS 3+OD, already supports back-up lights. The light fixtures were purchased on eBay.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-24-2017, 03:59 PM   #18
SeaSlugs
SeaSlugs's Avatar
manual trans S10's and blazers of all years work (82-05). 2 wire switch - grab the connector and as much wire as you can.
Old 05-24-2017, 04:22 PM   #19
Big hammer
My grandma said she could not follow find reverse in her T and just parked it so she didn't need reverse :-)
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 05-24-2017, 05:12 PM   #20
Big hammer
FYI when I back up I turn my head lights off, it helps, and if you ride the brakes the extra red light helps!
FYI turning your dash lights down also help to see the road! Ask my brother, he was complaining one night that he couldn't see well. I asked him if he could turn his dash lights down, he did and he said wow i can see better! He then said how I knew that, why would they put a dimmer on dash lights, to see better at night!
