06-30-2017, 04:46 PM | #1 |
Farmer Fix 1 - 14 Leaf Front Spring for 28 Tudor
Attached is a picture of my front spring; one of many "fixes" my car has acquired over its life. You can see the 4 extra leaves because they are square cut, not notched. I am guessing this was a solution to a weak spring. Strangely enough, the car and frame do sit at the proper height. Nonetheless, I will put a a new front spring on the car in September, but only 10 leaf!
06-30-2017, 04:53 PM | #2 |
Re: Farmer Fix 1 - 14 Leaf Front Spring for 28 Tudor
I'm amazed that it's not setting higher in the front.
Over the years with many owners some strange things happen. I would guess you will see an improvement in you ride with new correct spring. How are the shocks, and the rest of the front end? |
06-30-2017, 05:56 PM | #3 |
