Old 07-04-2013, 12:37 PM   #1
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Default 36 sedan dome light
Before I break something, what's the proper procedure for removing the dome light and/or lens on a 36 fordoor?
dean333 is offline   Reply With Quote
Old 07-04-2013, 12:52 PM   #2
Don Rogers
Don Rogers's Avatar
Default Re: 36 sedan dome light
There is a snap ring holding the lens inside the dome light housing.
Don Rogers is offline   Reply With Quote
Old 07-04-2013, 02:08 PM   #3
dean333
dean333's Avatar
The snap ring is holding the lens INSIDE the housing? How do you get at the snap ring without breaking the lens??
Old 07-04-2013, 03:20 PM   #4
PeterC
PeterC's Avatar
Use a fine pick type instrument and gently pry one end of the snap ring out and it will pop right out - the snap ring has two ends - just locate an end and "pick: it out and the rest will follow.
PeterC is offline   Reply With Quote
Old 07-04-2013, 05:21 PM   #5
dean333
dean333's Avatar
Thanks Peter, clip popped right out and flew into the front seat. Easy enough
