Old 12-28-2020, 04:57 PM   #21
alexiskai
alexiskai's Avatar
Default Re: Latest aluminum block.
Now I'm wondering if I absolutely need to use engine enamel to do the lettering, because if I do, the range of yellows available is, um, limited.
Old 12-28-2020, 05:25 PM   #22
Chris Haynes
Chris Haynes's Avatar
What is the benefit of an aluminum block on a touring car?
1921 Runabout
1930 Tudor
Early 1930 AA
Old 12-29-2020, 07:24 AM   #23
Tod
Originally Posted by johnneilson View Post
Inquiring minds want to know the Block status, has the eagle landed?
Not that the Winfield information isn't interesting.........
John
I am making blocks for mostly 5 main application, aluminum and iron. I have a few aluminum orders to fill and several 3 main iron blocks to do for waiting customers. Yesterday, I dropped off 2 truck loads of core sand for blocks, headers, OHV heads (all iron, and all sold already), Winfield heads (mainly 6:1), and more Stock Top Crow Foot heads (7:1 compression). I won't really have to wait long as there is more than enough there for a heat or two of just my castings. As usual, while getting ready for this run of castings, more inquiries were coming in. I'd rather operate one or two runs behind than cast a bunch of parts that have no buyers.
As I have been saying all along, I want my main focus of blocks to be 3 main A journal and B journal. Cylinder heads are easy to make any time.
Tod
Tod is offline   Reply With Quote
Old 12-29-2020, 12:21 PM   #24
katy
katy's Avatar
Do those aluminum blocks use sleeves?
Old 12-29-2020, 12:57 PM   #25
Tod
Yes.
Tod
Old 12-29-2020, 05:55 PM   #26
CarlG
CarlG's Avatar
And all of Tod's products are MADE IN THE USA!
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-30-2020, 10:54 AM   #27
katy
katy's Avatar
Originally Posted by Tod View Post
Yes.
Tod
Are the sleeves cast in? Or?
Just asking as I don't know squat about aluminum blocks other that that they're lighter than cast iron.
Old 12-30-2020, 11:29 AM   #28
California Travieso
Send a message via Yahoo to California Travieso
Chris,
The only two benefits I can think of are: 1) the lower weight of the aluminum block, and 2) Aluminum conducts heat better than iron.
Tod can tell us what the difference is between the weight of his aluminum head and a standard iron head.
It’s also unclear if there is a significant difference between the cost of a new aluminum head that is machined and ready to be assembled versus the cost to rebuild an original block.
David Serrano
California Travieso is offline   Reply With Quote
Old 12-31-2020, 09:56 AM   #29
Tod
Sleeves are inserted after machining. Sleeves are slightly larger in diameter than the bored cylinder in the aluminum. The block is heated up which allows the sleeve to slide in and then when the block cools the aluminum creates "crush" to hold the sleeves in place. There is also a flange around the top of the sleeve so that the gasket and head add to the pressure holding the sleeves in. I posted a picture of this on my FaceBook page with test/dry fitting of sleeves. It is attached. This picture is of a 3 main aluminum block that will be heading to a customer soon. I have quite a few blocks of various configurations under way in the shop right now. 3 main iron and aluminum as well as 5 main iron and aluminum. Half a dozen, or so, are slated for use with my OHV heads.
Another run of block castings, as well as heads (OHV, Winfield, Thomas, Stock Top Crow Foot) and cast headers are about to be poured.
I hope this helps.
Tod
File Type: jpg 121615407_1044794175947258_8432860273423560121_o.jpg (56.4 KB, 101 views)
Old 12-31-2020, 10:44 AM   #30
katy
katy's Avatar
I hope this helps. Tod
It does, thank you, much appreciated for the info and for your time.
Ken
Old 12-31-2020, 12:12 PM   #31
rotorwrench
rotorwrench's Avatar
That looks really good. The sleeve top edge is visible in the image and is definitely wide enough.
Old 01-01-2021, 10:24 AM   #32
40 Deluxe
Originally Posted by California Travieso View Post
Chris,
David Serrano
#2 is actually a detriment, not an advantage! You want to keep as much heat as possible in the combustion chamber. Heat that is conducted away from the combustion chamber into the cooling system or surrounding air is wasted energy! Obviously, combustion temperatures must be controlled to avoid detonation, but overcooling is not good!
Old 01-01-2021, 10:46 AM   #33
rotorwrench
Thermostats eventually came along the pike in order to keep temperatures at peak performance standard for liquid cooled internal combustion engines.
The model A predates that but then they weren't a pressurized system yet either. An aluminum block will make some difference but not a lot. It's lighter for those that want to get in the performance applications. Die hard restorers would more likely stick with cast iron for the most part. I can see a place for both types.
