12-31-2021, 11:02 PM | #1 |
Head gasket
Water port on gasket but not on block BETWEEN #2&3
DO I DRILL THE BLOCK?? |
01-01-2022, 12:30 AM | #2 |
Re: Head gasket
No...
The Master Cylinder Enjoying life at the beach in SoCal... |
01-01-2022, 09:06 AM | #3 |
Re: Head gasket
The gasket is designed to fit a variety of different engines. Some have the hole, some don't. You do not have to modify the engine to fit the gasket.
Head and block should be flat and clean. Torque to specification and retorque according to the directions. Depending on the gasket and parts you may want to use the spray copper gasket cement. Consult the Model A Mechanics Manual, Vol 1 for instructions if you don't have them already.
01-01-2022, 12:00 PM | #4 |
Re: Head gasket
