Old 10-26-2020, 07:41 AM   #1
adileo
adileo's Avatar
Default 52 F1 question
Hi folks
This looks like pretty straight forward job, but I’ve never done it and would like to know if it’s as simple as it looks.
As you can see the rear seal needs replacing.
Remove the two U bolts.
Remove drive shaft
After that does the seal just pull out. Is there a nut securing it in. If yes what size is it?
File Type: jpg 751076BA-83C2-450E-9E56-78CE4A695E10.jpg (48.8 KB, 29 views)
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 10-26-2020, 10:16 AM   #2
1948F-1Pickup
1948F-1Pickup's Avatar
Default Re: 52 F1 question
Just thinking about doing that job the other day.
You'll have to remove the nut and pull the companion flange.
Regular puller for that job. Nut is 3/4-16 thread, 1 1/8" hex.
Since the pinion bearing preload is involved, I'd probably
mark the nut, pinon & companion flange before removing the nut.
R&R the seal and then everything in the reverse order.
There's a companion flange tool mentioned in the manual
to keep that item from turning while you torque the nut.
The nut gets torqued to 140-180. Theoretically, the marks
you placed on the nut and pinion should line up somewhere in
that torque range.
1948F-1Pickup is offline   Reply With Quote
Old 10-26-2020, 10:55 AM   #3
adileo
adileo's Avatar
Excellent detail tyvm
Thanks
Andy
1952 F1
