Old 03-30-2019, 09:54 PM   #1
Steves46
Steves46's Avatar
Default Alternator Pulley
Forgive me if this is a dumb question but I am new to Model As and alternators on classic cars. My fan belt has 1 inch play and I can turn the alternator pulley by hand...is this too loose? My Les Andrews book Vol II does address ensuring the belt is tight when installing an Alternator but does not indicate amount of play. Greatly apprecaite any guidance.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 03-30-2019, 11:23 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Alternator Pulley
Steve consider it this way. The alternator will generally be more difficult to rotate as the load requirement increases. Exactly how much of an electrical load does your system require? If your system is drawing a max of 15 amps for a unit that is rated at 60 amps, the pulley resistance is so minor that a loose belt is never noticed. On the flip side, run a fan belt too tight and you will find the water pump will fail as it was never designed to have a tight-tensioned belt.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 03-31-2019, 03:54 AM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Common sense will tell you how TIGHT/LOOSE your belt should be!!!!
Are we going to do PAGES/PAGES, about the belt tension???? Do you check your Shoe-Laces that often??
Bill Laughing
"THE ASSISTANT GURU OF STUFF"
Old 03-31-2019, 10:24 AM   #4
Badpuppy
Bill Laughing
Been missing you, Bill. Good to see you're still checking your belt and keeping your pants up.
Badpuppy is offline   Reply With Quote
