Old 04-01-2021, 01:51 PM   #1
hardtimes
hardtimes's Avatar
Default flywheel info
I have a '32 stock flywheel.
A machinist acquaintance said that he has never 'lightened' such equipment.
Is there any posted info , like a diagram, etc, in writing...that I could give him as directions on 'how to lighten an A/B flywheel ?
If so, could you please direct me to copy such for this machinist !
Thanks
BTW..this B flywheel is 54 lbs stock with bearing and ring gear.
Old 04-01-2021, 02:29 PM   #2
JayJay
Default Re: flywheel info
Thanks
Les Andrews Vol. II has a discussion on how to lighten an A flywheel, including diagrams of where to remove metal.
Not trying at all to start a discussion on whether you should do this.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
Old 04-01-2021, 02:40 PM   #3
MALAK
MALAK's Avatar
I just did one a couple of weeks ago.
MALAK is offline   Reply With Quote
Old 04-01-2021, 06:06 PM   #4
hardtimes
hardtimes's Avatar
Hey Malak,
This looks to be helpful info..... if only I could read it !
Dont know if it’s my CVS oily glasses or.... what ?
Old 04-01-2021, 06:09 PM   #5
hardtimes
hardtimes's Avatar
JayJay
Hey Jay ,
I think that I have that written info. Ill check it out
Old 04-01-2021, 08:32 PM   #6
Charlie Stephens
I would look for another machinist. I have it in the back of mind that one of the prints contained errors so you might compare a couple.
Charlie Stephens
Old 04-01-2021, 10:28 PM   #7
pbishop
BING / GOOGLE a local Model A club near you to find a machine shop also near you that has expertise with the process. Much quicker acceleration, less stress and wear on main bearings, and shifting is smoother, particularly when having to 'double-clutch'. Some say that they then did not have to D-C. I also found an increase in mph.
pbishop is offline   Reply With Quote
Old 04-01-2021, 11:24 PM   #8
Benson
Charlie Stephens
Yes there are two versions
1. The first was published in S.O.S.S magazine (as I remember) and has an error.
2. The second one issued shortly after the first corrected the error.
Old 04-02-2021, 01:22 AM   #9
hardtimes
hardtimes's Avatar
Hey Charlie and Benson,
Thanks for your info/help.
Yeah confusing info is costly too
Anyone have access to second version ‘ how to ‘ ?
Old 04-02-2021, 05:39 AM   #10
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
I do, but I'm going to suggest you convert the flywheel to accept the V8 style pressure plate and stop there. If anything else, just remove 0.050 off of the outside to clean it up. IMO, too light is worse than a little heavy.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 04-02-2021, 07:51 AM   #11
kenparker0703
I concur with Brent. I have three cars with V-8 pressure plates. One has a 42 # flywheel, One has a stock Model A flywheel - 64#, and one has a V-8 flywheel - 54#. As faar as daily driving I can not tell the diference. The light one at 42# was built for my racer.
kenparker0703 is offline   Reply With Quote
Old 04-02-2021, 12:00 PM   #12
Jim Brierley
Mine are all in the 30-35 lb. range. The last two I did, I had them drilled for a diaphragm clutch, very smooth!
Old 04-02-2021, 07:04 PM   #13
nkaminar
nkaminar's Avatar
You can buy a lightened clutch from Snyders for $475 with the V8 clutch. It is balanced and ready to go. Probably cheaper than having a machinist turn your flywheel, buying the clutch, and having the sum balanced. Also, less risk.
Old 04-03-2021, 02:49 AM   #14
hardtimes
hardtimes's Avatar
Hey Ken,
Like you state, I have used several wts flywheels in several different B engines.
I’ve driven stock A/B engines for long time.
As Jim B, I’ve used 35 lb as lightest in 30 roadster. This one drove easiest and smoothest with V8 PP.
I have one that is near running stage with a Stipe aluminum flywheel and V8 setup. This one will have ton of power, so light flywheel will do.
The new Burtz flywheel is 30 lb and balanced to use with his engine.
Im actually at a stage/crossroads where I need to make the flywheel lightening decision... on the B Im working. The stock poured bearings are a consideration here also, eh !
Old 04-03-2021, 04:31 AM   #15
updraught
updraught's Avatar
Hey Malak,
Bigger version. I assume it is the corrected one.
https://www.jalopyjournal.com/forum/...wheel.1030778/
updraught is offline   Reply With Quote
Old 04-03-2021, 04:15 PM   #16
hardtimes
hardtimes's Avatar
Hey updraught,
THAT is much better for my old eyes. Thanks.
Now.....anyone can help if this IS THE GOOD DRAWING ?
Also, is there a way you know of to copy this onto paper copy... to hand to a machinist ?
Old 07-28-2022, 07:43 AM   #17
rwh
Jim,
What diaphragm clutch did you use? Seems to be lots of debate related the the throwout bearing interface with the fingers. Also, whether to use 9" or 10" .
Thanks in advance for your reply. Much easier to learn from someone that has done it.
Richard
rwh is offline   Reply With Quote
Old 07-28-2022, 10:14 AM   #18
nkaminar
nkaminar's Avatar
This is a note on how a lightened flywheel works. It is not advice on whether to use it or not.
All crankshafts vibrate in torsion at all speeds. There is always a node point where there is no vibration with the torsion being ahead and behind that point. With the heavy stock flywheel the node point is right at the flywheel which means that no torsional vibration is felt at the flywheel. When the flywheel is lightened the node point moves forward so that now there is some vibration in the flywheel. You can feel this in the steering wheel when driving a car with a lightened flywheel. It smooths out at higher rpm.
Even though there is no torsional vibration felt with the stock flywheel does not mean that the crankshaft is not vibrating in torsion. It is at all rpm's. It will vibrate more at a critical speed which is a higher rpm.
Old 07-28-2022, 11:03 AM   #19
nomadpsd
nomadpsd's Avatar
Originally Posted by rwh View Post
Jim,
Richard
It's a Ranger, Mustang, Thunderbird pressure plate. It is a 9" diaphragm. The bolt pattern is unique and uses dowel pins to locate it. I used the Sachs SC0047. Bought it from Amazon. I used a disc from Speedway for the Camaro V8 T5 trans. This diaphragm clutch will not work with the stock trans. The fingers bind on the input sleeve when depressed (Personal experience). Here is a drawing of the bolt pattern. Also shows where I lightened it. I used Ford Racing M6397A302 Pressure Plate Bolt and Dowel Kit.
nomadpsd is offline   Reply With Quote
Old 07-28-2022, 11:05 AM   #20
johnneilson
Jim,
Richard
Richard,
there are several ways to do it, have worked on a couple.
there are a couple PP from Mustang and Ranger that will work.
in order to do it correctly, the flywheel must be drilled with the proper pattern AND have the locating pins installed. the difference between the long finger and diaphragm is only a 1/16" on the bolt holes and just hogging out the holes is not the proper way to do it.
John
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
