01-21-2022, 01:46 AM | #41 |
Re: Speaking of engines
Thanks for the better pics.Might be an LB. Pull the pan and a main cap.
01-21-2022, 08:35 AM | #42 |
You guys just need to learn to count to 21 . . . even if you need an extra finger or toe!
01-21-2022, 03:08 PM | #43 | |
Those are both good. Until now, I always looked for either TWO at each end (21-stud), or THREE at either end (24-stud). Slight change of topic: Did anyone realize that V8-60 heads are the only V8-FLATHEADS with NO STUD above spark plug holes? DD . |
01-21-2022, 07:52 PM | #44 |
I did not know that. Seems an odd way to bolt down a head! Always learning on the barn, thanks
01-21-2022, 10:09 PM | #45 |
Thanks all for the excellent information and sources. Until I can pull the pan and inspect the bottom end we can conclude it's a '35/'36, unknown whether it's an LB or not. Another question is would this have had cast iron or aluminum heads from the factory? I have quite a stack of 21 stud heads and if possible I'd like the correct heads on it. Would the factory heads have any casting script or numbers on them? I can dig through the pile and see if I know what to look for.
01-22-2022, 02:18 AM | #46 | |
Here's a picture!! DD |
01-22-2022, 02:35 AM | #47 |
I found this on Portland Oregon CL. Is this a V860? Also found another posting. Seriously?
https://portland.craigslist.org/clc/...435897792.html https://portland.craigslist.org/clc/...433186624.html |
01-22-2022, 02:39 AM | #48 |
Both listed correctly. Quite pricey for the '37 IMO.
01-22-2022, 02:43 AM | #49 | |
Aluminum for pass car and cast iron for commercial from what I understand.OEM should have the part number embossed as well as Ford script. '35 prefix part number begins with 48, for example 48-6050 or 48-6049 in '36 it begins with 68 like 68-6050 or 68-6049.The '36 heads should be for domed pistons. Last edited by deuce lover; 01-22-2022 at 02:53 AM. |
01-22-2022, 02:47 AM | #50 |
Thanks much. I'll report back.
01-22-2022, 02:55 AM | #51 |
Well, I am no expert, but the 2 oil ports on the rod journals is an 8ba crank, no? and no photo of a "magneto" , which would be worth some dough. I'd say he is one zero off market value
01-22-2022, 03:03 AM | #52 |
Battle ground is only about 80 miles from me. I'd be willing to go pick it up for you at his asking price. LOL
01-22-2022, 11:56 AM | #53 |
the engine in the picture 35 or earlier it would have the water pumps in the heads and if you take the pan off it should have babbit main bearings. I have built a few of these motors.
