Old 12-19-2019, 09:51 AM   #1
Subsailor
Default Oil filter adapter question
I am replacing the oil filter adapter (canister to screw on) on my 272 because it was leaking from the gasket area that goes between the adapter plate and the block. Received the new one yesterday from "Macs". The instructions say that the 1" slot cut through the plate goes on top and stamped into the plate about 45 degrees away from that slot is the word "top". So, any ideas which is correct? I am leaning towards going with what the instructions say, but thought I better ask others that have installed or replaced one of these. Thanks.
Glenn
‘56 F100 272
Pacific Northwest
Subsailor is offline   Reply With Quote
Old 12-19-2019, 12:43 PM   #2
darrell
Default Re: Oil filter adapter question
the slot goes to the top.i heard of those with top in the wrong place china.
darrell is offline   Reply With Quote
Old 12-19-2019, 01:19 PM   #3
Subsailor
Thanks Darrell. Going to see if I can make it work without leaking.
Glenn
‘56 F100 272
Pacific Northwest
Old 12-19-2019, 01:46 PM   #4
dmsfrr
dmsfrr's Avatar
Originally Posted by Subsailor View Post
. . . Going to see if I can make it work without leaking.
I hope you have better luck with them than I did. Fired up a new engine the first time, the gasket blew out and dumped at least a Qt of oil on the floor. Replaced it with another kit and it blew out a couple days later, also on the garage floor. Glad it wasn't out on the road somewhere.
Not sure what the torque spec for the big nut is but don't over-do it, 20 ft lb may be more than enough. The floppy rubber gasket can tend to squish out.
I solved it with a machined aluminum adapter that uses an O-ring.
dmsfrr is offline   Reply With Quote
Old 12-19-2019, 02:01 PM   #5
Subsailor
Thanks for the tip about over tightening. Hopefully it will work and I won't be cleaning up a mess.
Glenn
‘56 F100 272
Pacific Northwest
Old 12-19-2019, 02:11 PM   #6
darrell
there is no secret to these things.ive had 2 or 3 in a row that didnt leak and figured ive got it now.then 2 that leaked.sometimes it took 3 tries to stop it.
Old 12-19-2019, 05:59 PM   #7
Daves55Sedan
Daves55Sedan's Avatar
I'm surprised to hear about the leakage problems. I converted two Y-blocks with spin-on adapters and never had one problem. Makes me wonder if the gasket they are making for these are too soft now. I recall my gaskets being fairly rigid, to the point that you need to smear a little axle grease in the groove to hold the gasket in place while installing the plate. Works great.
Daves55Sedan is offline   Reply With Quote
Old 12-19-2019, 09:32 PM   #8
paul2748
paul2748's Avatar
At one time Mac's had a extra thick gasket - don't know if they still have it.
On my 56 Bird, I did the change twice - both times leaked. Went back to the canister and had no more problems.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 12-20-2019, 02:04 AM   #9
KULTULZ
KULTULZ's Avatar
Post Re: Oil filter adapter question
The main problem is the kit being aftermarket. The adapter plate is stamped from lesser gauge metal and warps when tightening the adapter.
GENUINE FORD - B7A 6882-A
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 12-20-2019, 09:46 AM   #10
Jim Yergin
I solved my leakage problem by using the gasket that comes with the filter for the original canister type. It is much more substantial.
Jim Yergin
Jim Yergin is offline   Reply With Quote
Old 12-20-2019, 10:07 AM   #11
54vicky
54vicky's Avatar
mine has been on for almost 40 years with many filter changes no leaks ever.as already stated offshore quality(lack thereof)
54vicky is offline   Reply With Quote
Old 12-20-2019, 12:13 PM   #12
Ole Don
Ole Don's Avatar
Mr. Yergin has the answer in post ten. Buy a filter for a 55 Ford and use the fiber gasket. It is stiff enough to not squirt out like the modern rubber gasket.
Ole Don is offline   Reply With Quote
