Old 09-17-2018, 03:17 PM   #1
Track T-4
Track T-4's Avatar
Default 1937 Ford door window felt
Are window "felt" and "anti-rattler" the same thing? I'll use "felt" for the purpose of explaining this post.
I need to install the interior side of the window felt for the glass on both doors of my '37. The exterior felt is in place but the interior side is non-existent. So my questions are:
1. How is the interior felt attached to the garnish molding? I've heard glued, stapled and screwed but there are no holes in my garnish molding.
2. Why do some felts have a stainless trim? Was this for deluxe models?
3. Can I purchase just the interior felt? If so, where?
4. Is "felt" and "anti-rattler" the same thing?
Thanks!
Track T-4 is offline   Reply With Quote
Old 09-17-2018, 07:46 PM   #2
swoopNZ
MEMBER EMERITUS
Default Re: 1937 Ford door window felt
1. Clips and sometimes staples. No holes = clips.
2. Aftermarket usually for 37-39.
3. Not sure.
4. Yes - in that they serve the same purpose.
swoopNZ is offline   Reply With Quote
Old 09-17-2018, 11:06 PM   #3
Brian
Brian's Avatar
For the felts, try Steele Rubber Co, part # 40-0539-57
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 09-18-2018, 07:17 AM   #4
marko39
i just did mine on my 39 tudor and the orriginals were stapled to the garnish mouldings. the new kit comes with both staples and small screws which i used as i could not staple thru the metal. the kits i used are made by Vintique and are of good quality but only come as sets to do the whole window. Mark
marko39 is offline   Reply With Quote
Old 09-18-2018, 10:09 AM   #5
Track T-4
Track T-4's Avatar
mark039,
Where did you buy yours? Any problem or possibility of the screws hitting or scratching the glass?
Track T-4
Old 09-18-2018, 12:05 PM   #6
40cpe
40cpe's Avatar
The screws provided are very small, maybe #4, flathead. They are inserted through the felt into the garnish and the head buries itself in the felt.
40cpe is offline   Reply With Quote
Old 09-19-2018, 07:23 AM   #7
marko39
Originally Posted by Track T-4 View Post
mark039,
Track T-4
i got mine from Early Ford Sales ( best price around 100.00) have 2 pieces leftover will send you a PM.
