Old 01-12-2022, 04:44 AM   #1
Shampipple
Shampipple's Avatar
Default 8ba/39 truck woes.
I had an issue I thought I’d inquire about. 49 8ba, truck bell, truck flywheel and oil pan, 39 transmission.
The flywheel was tight against the block. I had to take it all apart and add a shim between the crank and flywheel.
Has anyone else ran into this issue? The shoebox flywheel is not cut as deep in the pocket.
Not a huge issue, but I’m curious about the difference.
29 Model A Roadster, 39 Pickup, 50 Custom Tudor, 66 Mustang Fastback, 79 F350, 02 Thunderbird
Shampipple is offline   Reply With Quote
Old 01-12-2022, 07:24 AM   #2
Charlie ny
Default Re: 8ba/39 truck woes.
Remove the shims and get the correct flywheel. Those shims are like a sponge.
Charlie ny
Old 01-12-2022, 09:32 AM   #3
51504bat
51504bat's Avatar
Easy way to tell an 8ba flywheel from an earlier model. On an 8ba the pressure plate bolt holes go completely through the flywheel. On early blocks they don't.
51504bat is online now   Reply With Quote
Old 01-12-2022, 09:39 AM   #4
tubman
tubman's Avatar
To put it bluntly, early and 8BA flywheels do not interchange. The flywheel must match the engine.
Old 01-12-2022, 02:35 PM   #5
Shampipple
Shampipple's Avatar
Thanks guys.
I’ll have the 8ba drilled and surfaced too. This group is full of priceless knowledge!
Old 01-12-2022, 03:51 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
I didn't know it wouldn't work, I turned some off the back of the 11" truck flywheel when putting the 49 merc into the big truck, modified a starter drive to get full engagement----
Old 01-12-2022, 06:13 PM   #7
kirkf
kirkf's Avatar
How are you handling the cooling fan?
Kirk
1953 Ford F100
1950 Ford F47 (F1)
1940 Ford Pickup
kirkf is offline   Reply With Quote
Old 01-12-2022, 09:19 PM   #8
Shampipple
Shampipple's Avatar
That’s why I tried shimming mine.
Old 01-12-2022, 09:20 PM   #9
Shampipple
Shampipple's Avatar
Kirk
I haven’t gotten that far yet. Once the cab is back on I’ll start measuring.
I think I’m modifying the shoebox radiator to fit, or I have a couple other candidates.
Old 01-13-2022, 05:14 AM   #10
Shampipple
Shampipple's Avatar
Kirk
I hope to use the mechanical 8ba fan, even if I have to set the radiator a little farther forward. I don’t mind electric fans, I just don’t want to go that route if I can help it.
Old 01-19-2022, 08:29 PM   #11
kirkf
kirkf's Avatar
I measured my clearance from firewall to radiator this week, and it appears there is 32" of room.
On my truck there would be no way to move the radiator forward.
Kirk
1953 Ford F100
1950 Ford F47 (F1)
1940 Ford Pickup
Old 01-20-2022, 02:03 AM   #12
Shampipple
Shampipple's Avatar
Kirk
Thank you!
I’ll figure something out once I get my flywheel back and cab installed.
Old 01-20-2022, 07:24 PM   #13
39portlander
39portlander's Avatar
Kirk, No woe's brother we are here to help you out. Do what ever you need with the flywheel arrangement to get that 8BA installed.
Don't worry about the cooling fan, I had Brasswork build my radiator for my 39 with a Spal cooling fan. No fan off the crank makes a big clearence and balance difference.
The sensor that is installed in the head with my fan relay is a perfect set up. My 39 will run cool as a cucumber all summer long.
I had posted about my installation and set up but any pictures you need I can post for you. I have a 59AB but no matter the radiators are the same.
39portlander is offline   Reply With Quote
Old 01-22-2022, 08:16 PM   #14
Shampipple
Shampipple's Avatar
Thanks. I’ll search the post. I should get my flywheel back on Monday. I’ll reinstall the engine. Hook up my exhaust.
I just finished the firewall. I’m painting the underside of the cab tomorrow. Once I get the cab on I can start measurements for the radiator. I may go the brassworks route, but I have three various flathead radiators in house. I’m going to try to modify one to fit. It looks like my shoebox radiator will fit with minor mods and use the mechanical fan.
Old 01-29-2022, 07:36 PM   #15
Shampipple
Shampipple's Avatar
Thank you all.
She’s sorted and running.
Old 03-07-2022, 08:24 PM   #16
Shampipple
Shampipple's Avatar
Just a follow up on this subject.
I’m really happy with the route I took, and thought I’d share what I did.
I used the 8ba 49 ford shoebox Radiator and core support. I welded it to the frame.
In order to fit the body, I had to trim the flange and support just above the second mounting bolt.
The last photo is where I’ll have to trim the sheet metal air duct from behind the grille. I may even bend it rather than cut it off. So far so good.
It runs the original generator and fan from the 49 wide belt stuff out of the Shoebox. I’m running a 12volt regulator.
