01-17-2022, 12:25 PM | #1 |
Thread size for 36 water pump temperature sensor?
Does anyone know the thread size for the temperature sensor that goes into the left water pump?
I'm asking because I'm trying to see if this might be work around solution for the stock gauge. https://www.yesterdaystractors.com/U...IaAuTyEALw_wcB Sent from my LM-V405 using Tapatalk
Thanks Rick McKenney Seattle WA |
01-17-2022, 12:46 PM | #2 |
Re: Thread size for 36 water pump temperature sensor?
It doesn't specify the thread size of the unit you're looking at, but it has a bushing that will allow it to fit two sizes. I'd be willing to bet that one of them will fit your car. (Ford made tractors too, you know.)
01-17-2022, 12:48 PM | #3 |
Rick, yes that will fit; it is the std 5/8 UNF thread as is the hole in your watewr pump
01-17-2022, 03:35 PM | #4 | |
Bill |
01-17-2022, 07:17 PM | #5 |
the 36 water pump provision also has the seat...you will not need the adapter that comes in the kit; the bulb and nut will directly fit the pump housing
01-18-2022, 12:58 AM | #6 |
01-18-2022, 01:32 AM | #7 |
Thanks, guys.
