Old 10-16-2023, 05:59 PM   #1
[email protected]
Default 28-29 Roadster Convertible Boot Source
ISO 28-29 Roadster (Convertible) Boot -- Source or pattern.
gedoane@bellsouth.net is offline   Reply With Quote
Old 10-17-2023, 06:48 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: 28-29 Roadster Tonneau Cover Source
Originally Posted by [email protected] View Post
ISO 28-29 Roadster Tonneau Cover Source or pattern.
You are likely on your own with this as your method of attachment vs. others will vary enough making a pattern for a universal cover useless. Any experienced trimmer should be able to fabricate one for you. Likely there will be images you can find on the web that will give you inspiration.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-17-2023, 08:03 AM   #3
ronn
you could buy a 30-31 and trim it down...........
Old 10-17-2023, 08:58 AM   #4
gdmn852
gdmn852's Avatar
Default Re: 28-29 Roadster Convertible Boot Source
Hello,not sure how well a 30-31 STANDARD roadster would fit, might need modifications, Standard roadster top would be similar to the 28-29 model than a deluxe.Good luck on your quest.
gdmn852 is offline   Reply With Quote
Old 10-17-2023, 09:29 AM   #5
springerpete
springerpete's Avatar
Find a boat upholstery shop and take your roadster for them to look at. Fall is often a slow time for them and those folks are very clever fitting odd shapes. I have a '29 and my boot is light, black canvas. Too bad we are not closer and I'd lend it too you. Pretty wintery here in Maine now. Bill
springerpete is offline   Reply With Quote
Old 10-18-2023, 01:06 PM   #6
rotorwrench
rotorwrench's Avatar
Classtique offers top boots as well as side curtains. They are very busy right now so it may take them a quite to fill an order.
