Old 09-30-2020, 05:17 PM   #21
eagle
eagle's Avatar
Default Re: Mystery missfire .
With an updraught carb its not as easy. Run a hose into the container, put the other end of the hose into the carb throat, then hold your hand or a rag in the carb throat to make enough vacuum in the tube to suck some up. Either Sea Foam or Marvel Mystery oil is a miracle cure sometimes.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 09-30-2020, 06:47 PM   #22
Licensed to kill
Licensed to kill's Avatar
That's why I suggested the hose/funnel in the vacuum port in post #14
Licensed to kill is offline   Reply With Quote
