Go Back   The Ford Barn > The Archives > Model-A
Old 01-01-1970, 12:00 AM   #1
Guest
Posts: n/a
Default Head Torque and etc., etc...
Quick.....need to know the correct sequence of torquing the head bolts on my 29 Roadster. Also....what should I use for sealing various gaskets???? I'm also having trouble removing the fan and pulley from shaft to rebuild water pump. I have soaked it in penetrating oils and tried a conventional pulley puller but was about to bend pulley....now what?? Thanks, Larry
