Old 06-01-2015, 06:38 AM   #21
C26Pinelake
Default Re: Starter Swtitch
Try the crank as Paul said. Wayne
C26Pinelake is offline   Reply With Quote
Old 06-03-2015, 05:46 AM   #22
Franchise_24
Franchise_24's Avatar
Yeah I did, saw the flywheel turning, put the starter back in and I found I had a wire grounding out that goes to my cutout, so I'm guessing that is why the car went dead and no action from the starter. Fixed that up and the car started and ran fine. Thanks for all the advice.
1929 Model A Ford Coupe
Franchise_24 is offline   Reply With Quote
Old 06-03-2015, 06:55 AM   #23
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Starter Swtitch *fixed*
That short could blow a fuse or smoke the charging circuit wires, but should not have stopped the starter from turning, unless it killed the battery.
Also what happened with the flywheel jamming when turned in one direction?
Old 06-03-2015, 08:52 AM   #24
Skeezixx
Skeezixx's Avatar
Originally Posted by H. L. Chauvin View Post
I knew a guy who installed a small campaign sign out front during a local election, and the next morning his car was sabotaged leaving no air in his (4) tires.
Anything can happen these days. LOL
This reminds me. I live in New Orleans and I knew a guy who had to replace his rear window three times in as many weeks. On the last time he also removed the "David Duke for Governor" bumper sticker and his problem was solved.
Skeezixx is offline   Reply With Quote
Old 06-03-2015, 11:51 AM   #25
Franchise_24
The flywheel wasn't jammed it turned just fine. If it was grounded out I would think that would prevent the battery from making the starter turn?
Old 06-03-2015, 12:55 PM   #26
Tom Wesenberg
If the battery was good then the short should have blown a fuse or smoked the wires. Since the wires didn't overheat I suspect a poor connection at the battery posts or ground. It may have corrected itself during the troubleshooting, but if it happens again you know where to look.
Old 06-04-2015, 08:11 PM   #27
Franchise_24
Ok. I had the floor boards out and tightened my connections on the battery, so it may have been a combination of things.
