Old 12-05-2011, 10:57 PM   #1
C26Pinelake
Talking What is the hardest Model A accessory to find
Is there one accessory that seems to have disappeared and what was it ? Do you have a rare accessory and want to sell it. Give me an email and lets talk wayne
[email protected]
C26Pinelake is offline   Reply With Quote
Old 12-06-2011, 12:15 AM   #2
azmodela
Default Re: What is the hardest Model A accessory to find
"What is the hardest Model A accessory to find"
The accessory I don't have.
azmodela is offline   Reply With Quote
Old 12-06-2011, 12:26 AM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
My '29 coupe has a 1 1/2 inch drop block on the steering column mount. Lots of patina. I think I read somewhere that they were used on 400-A's, phaetons, and vickys?? One supplier is selling repros for $35.00. Longer bolts must be used with drop block.
"THE ASSISTANT GURU OF STUFF"
Old 12-06-2011, 12:18 AM   #4
RcT
There are two very rare examples on ebay item 190610829514. It's an early '28 roadster with very cool after market headlight lens and the most elegant rear view mirrors I have ever seen. "Nymph" rear view mirrors, mounted on the dual spares... I, who have always thought too many excessories detracts from the car, will admit, I love these two items.
Richard
RcT is offline   Reply With Quote
Old 12-06-2011, 01:48 AM   #5
dave in australia
Richard
They are beautiful, I've never seen mirror mounts like them before. Now, I want a set.
dave in australia is offline   Reply With Quote
Old 12-15-2011, 11:01 AM   #6
IrishHills
IrishHills's Avatar
Richard
IrishHills is offline   Reply With Quote
Old 12-06-2011, 01:30 AM   #7
dynaflash_8
dynaflash_8's Avatar
id think that the model A snowmobile conversion is about the hardest to find.
https://www.youtube.com/watch?v=ve9s223EKT4
dynaflash_8 is offline   Reply With Quote
Old 12-06-2011, 10:19 AM   #8
Steve Wastler
Steve Wastler's Avatar
I think the hardest to find, unautherized accessory is the gas tank filler box. There was a post a year or so ago about them, soon after one showed up on ebay, brought big money. Sorry I don't have a picture...
Steve Wastler is offline   Reply With Quote
Old 12-06-2011, 10:20 AM   #9
Steve Wastler
The Tux away rumble top is a rare one also.
Old 12-06-2011, 11:09 AM   #10
Steve Plucker
I think the hardest accessory to find are the Lap Robes. I have only seen just one example.
They were:
52" x 64": A-18545-A (Gray); A-18545-B (Blue); A-18545-C (Brown);
52" x 58": A-18545-A1 (Gray).
Why? Deteriotion of the cloth over the past 80 years or so.
Introduced in early 1931.
I bet between all of us we could put together a great "site" showing all the Ford Accessories if there is not one already...is there?
Pluck
Old 12-06-2011, 10:59 AM   #11
Marcus
Marcus's Avatar
Anyone have a picture of these fender mounted parking lights?? I have a set mounted on a set of 29 CCPU fenders obtained from a friend, and if they are rare, then I need to return the lights to him. Obviously, I am NOT an expert on the "A" - nor much of anything else!! If you have a picture or a reference - please send it to [email protected].
WARM REGARDS, MARCUS
Marcus is offline   Reply With Quote
Old 04-07-2020, 09:07 AM   #12
Badpuppy
The lamp heads are identical to the cowl lights; the hard parts to find are the mounting arms, shielded wire and whatever clips used on the fender brackets. They used a dash switch with early 3-position lighting switches, but connect directly into the later 4-pos.
Old 12-06-2011, 11:15 AM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
I'd like to find a rear end that looks completely stock, but has an overdrive in the differential. It's in that yellow accessories book.
Old 12-06-2011, 11:18 AM   #14
1930artdeco
1930artdeco's Avatar
Hi Steve,
There is a site for accessories-I will try and find it and post it.
Here it is: http://users.erols.com/b-dwheeler/indexacc.html
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 12-06-2011, 12:37 PM   #15
Joop
Joop's Avatar
Originally Posted by 1930artdeco View Post
Hi Steve,
Mike
Here you go
Click here: RARE MODEL A ACCESSORIES
Joop is offline   Reply With Quote
Old 12-06-2011, 12:09 PM   #16
Purdy Swoft
Purdy Swoft's Avatar
The cast iron dual updraft manifold, like I have on my roadster is not easy to find. xxx
Old 12-06-2011, 12:29 PM   #17
Steve Wastler
purdy, nice set up, but for me, it looks like the carb almost touches the tail pipe. It would be my luck if I was running that, the rear carb needle and seat would get debris to stick it open and catch my car on fire...
Old 12-06-2011, 01:26 PM   #18
Purdy Swoft
Thanks Steve, it is hard to tell by looking at the picture but the Trojan manifold has long runners and stands way out from the exhaust manifold. It was necessary to drill a new hole for the choke rod. Any debris that would enter the choke end of any carburetor would go up the manifold and out the exhaust. Debris would have to enter through the fuel line to clog the needle valve. Here is another dual updraft manifold that I run on my speedster. This intake hugs the exhaust manifold like the original but the rear carb angles outward to help clear the exhaust manifold and prevent breathing the hot air. This manifold was easier to set up because I didn't have to relocate the choke rod, it also outperforms the Trojan because of larger runners and swan design. xxx
Old 02-22-2012, 03:57 PM   #19
Erskine48
I acquired this with a 30-31 truck axle, front axle overload spring. Bob E.
Erskine48 is offline   Reply With Quote
Old 04-08-2020, 08:08 AM   #20
mcgarrett
I was thinking a Model A Ruckstell overdrive transmission would be the holy grail.
