02-24-2020, 06:50 PM | #1 |
steering column wire clips
i've installed an old turn signal switch on the 34, a signal stat 700. i want a clip that holds the wire harness to the side of the column. it seems to me my old 63 ford truck had a clip like that for the factory signal wires, and i think many others, like 50's gm stuff too. its a C shape with a bump out the back for wires to go thru, and just clips on the tube. i checked all the ford vendors, cant even find a picture. googling brings up more clips than you ever thought existed, but plain old C clips, no. help my memory, was that a ford truck part? is there a proper name to search? any ideas? thanks, skip
02-24-2020, 07:21 PM | #2 |
Re: steering column wire clips
I bet you could make one using the metal banding strap material.
02-24-2020, 07:27 PM | #3 |
i had thought of that too, even have a piece in stock. its kinda wimpy, i think the real deal was thicker
02-24-2020, 07:58 PM | #4 |
I know exactly what you are referring to, but have no idea of what they are called or where to get them. Sorry. The only thing I can suggest are the manufacturers of aftermarket turn signal kits or maybe column mount tachometers.
02-24-2020, 08:01 PM | #5 |
There was a thread on these a while back. Don't remember if it was here on the Barn or on the HAMB. Not much help, because I can not think of what they were called!
02-24-2020, 09:49 PM | #6 |
Maybe at a swap meet. Bruce
Works good Lasts long time |
02-24-2020, 11:10 PM | #7 |
No relation, but possibly helpful:
eBay item number:172710393909 |
02-24-2020, 11:48 PM | #8 |
boy, thats the combat duty clip there! https://www.ebay.com/itm/N-O-S-M151-...MUTT-G838-N-O- if i had one here, i would probably use it. i have some jeep stuff, i'll go shopping here tomorrow. also, midwest military is 20 miles away. thanks for looking
02-25-2020, 09:48 AM | #9 |
02-25-2020, 11:27 AM | #10 |
thanks for your effort J. now i also know my memory has not completely abandoned me yet. i sat behind the wheel of that 63 ford truck for 18 years looking at the clip!
02-25-2020, 12:04 PM | #11 |
I bought one of these for my project....works perfectly.
https://www.ebay.com/itm/N-O-S-M151-...S/172710393909 |
02-25-2020, 12:58 PM | #12 |
I made them out of banding straps, very easy. G.M.
www.fordcollector.com |
02-25-2020, 02:46 PM | #13 |
02-25-2020, 03:03 PM | #14 |
I would think the salvage yards would have them.
02-25-2020, 05:31 PM | #15 |
Mid Fifty F-100 Parts in Arizona has the clamps. Part # 2919-L $6.90 ea. Ph# 1-800-252-1956. www.midfifty.com.
02-25-2020, 05:44 PM | #16 |
Here is the clamp (source TJ posted).
02-25-2020, 05:48 PM | #17 |
02-25-2020, 06:05 PM | #18 |
geez, lots of input here, thanks folks!!! looks like midfifty ford is the way to go. thanks all, skip
