Old 08-19-2014, 07:38 PM   #1
Stick Shift
Stick Shift's Avatar
Default A head on a B block
I did a search and did not come up with anything. I was told you had to plug the two holes on a B block to run an A head. Any one have any input on this? Thanks Stick
Stick Shift is offline   Reply With Quote
Old 08-19-2014, 08:18 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: A head on a B block
This is true and I've posted a picture in the past. I threaded the block and used two set screws that take an Allen wrench. I turned the setscrews in just below the deck surface, then covered it with JB Weld. When the JB Weld thickened a bit I scraped it level with a razor blade.
Old 08-19-2014, 08:39 PM   #3
vulture
vulture's Avatar
Scott I have a B head you can have if you need it and can bring it to the swap. I know the B head has a better compression ratio.
Wanted Roadster Pick up thank you COLOR]
vulture is offline   Reply With Quote
Old 08-19-2014, 09:12 PM   #4
hardtimes
hardtimes's Avatar
Ooooh, you got a GOOD offer below that will preclude your having to do such plugs. Actually, there are FOUR of these quarter inch holes that should be plugged, if you intend to use the A gasket and aftermarket head.
The idea is to provide 'support' for the A gasket that is without these holes.
hardtimes is offline   Reply With Quote
Old 08-19-2014, 11:22 PM   #5
Stick Shift
Thanks guys. I was curious what would be the out come if the block did not get plugged? Would there be a chance of getting oil in the radiator?
Old 08-20-2014, 12:10 AM   #6
H. L. Chauvin
Hi Stick,
FWIW .......... just another different experience to share on plugging holes:
I ran a B engine with an A police head for years with no block holes plugged.
This B engine with an A Police head was also previously in my mechanic Uncle's boat for 15 years from 1932 until 1947 -- my uncle was born in 1905 & was a master mechanic -- he knew & taught me to never remove a head when the engine is hot -- so this A, Police high compression head never got warped, nor did the block because we never exceed 55 foot pounds.
Please call Mr. Ron Kelley, engine rebuilder in Texas for an ear full of his experiences & ask him how many heads & blocks he sees overstressed & warped at this center stud because of exceeding 55 foot pounds -- again, just different Model A experiences & input.
We installed this B engine with this police A head in my 1930 Coupe in 1958.
Also, the coolant in a Model A engine or a Model B engine is not at all pressurized.
Maybe just me; but why would this area leak if sealed with a good head gasket on a tight joint even with non leaking with a high compression head.
We always install the head gaskets with non-hardening Permatex No. 2 sealant on both sides .... more input.
However, if the B block or A head is warped here in the center, (where it usually warps at this very high stress point), it appears one may need to plug to plug the holes.
You asked for input, & this is just a different input -- everybody has input if you ask. LOL
H. L. Chauvin is offline   Reply With Quote
Old 08-20-2014, 12:10 AM   #7
pat in Santa Cruz
pat in Santa Cruz's Avatar
a B head breathes better than an A head too if you have that free offer in mind.. But if you're thinking of an A high compression head, then the A head modifications apply to those too.
pat in Santa Cruz is offline   Reply With Quote
Old 08-20-2014, 05:38 AM   #8
Bob Bidonde
Bob Bidonde's Avatar
There is no need to plug any holes in the Model "B" block. Use a Model "A" head gasket and it will cover the extraneous coolant holes in the Model "B" block.
Bob Bidonde
Old 08-20-2014, 08:33 AM   #9
Tom Wesenberg
While what Bob says is often true, my friend's B engine with an A head had block coolant holes right at the edge of the gasket. This is living on the edge, especially with oversize head gaskets, which most of them are.
Old 08-20-2014, 09:24 PM   #10
Stick Shift
Thanks for everyones information on the subject. Any thought or idea helps.
Old 08-20-2014, 09:30 PM   #11
Charlie Stephens
Look at an A gasket on a B block. The B combustion chamber is more heart shaped than the Model A. You will see at least 2 (and as someone suggested maybe 4) holes that are extremely close to the edge of the gasket and not clamped by the A head. These holes will probably leak water into the combustion chamber. There will not be an oil leak into the radiator.
Charlie Stephens
